* Measurement data measured by REW V5.40 beta 96 * Source: Umik-1 Gain: 18dB , MICROPHONE, R, volume: 0.318. Timing signal peak level -46.1 dBFS, measurement signal peak level -26.3 dBFS * Format: 1M Log Swept Sine, 1 sweep at 0.0 dBFS using an acoustic timing reference * Dated: Aug 19, 2025 11:52:59 AM * REW Settings: * C-weighting compensation: Off * Target level: 75.0 dB * Note: ; Delay -0.3225 ms (-111 mm, -4.35 in) using estimated IR delay relative to Acoustic reference played from SPEAKER R with no timing offset Clock adjustment: 34.4 ppm * Measurement: L Aug 19 * Smoothing: 1/3 octave * Frequency Step: 96 ppo * Start Frequency: 20.141602 Hz * * Freq(Hz) SPL(dB) Phase(degrees) 20.141602 28.386 103.8041 20.287556 28.429 102.6911 20.434568 28.483 101.2859 20.582645 28.550 99.5957 20.731796 28.634 97.6458 20.882027 28.736 95.4909 21.033346 28.857 93.2258 21.185763 28.998 90.9929 21.339284 29.158 88.9837 21.493917 29.337 87.4289 21.649671 29.532 86.5798 21.806553 29.741 86.6858 21.964572 29.961 87.9699 22.123737 30.190 90.6057 22.284054 30.423 94.6874 22.445534 30.660 100.1907 22.608183 30.896 106.9321 22.772012 31.129 114.5584 22.937027 31.358 122.6006 23.103238 31.581 130.5862 23.270654 31.795 138.1516 23.439282 32.000 145.0903 23.609133 32.195 151.3344 23.780215 32.378 156.9056 23.952536 32.550 161.8678 24.126106 32.709 166.2969 24.300934 32.858 170.2644 24.477028 32.995 173.8316 24.654399 33.124 177.0486 24.833055 33.245 179.9555 25.013005 33.361 -177.4145 25.194260 33.474 -175.0326 25.376828 33.589 -172.8723 25.560719 33.708 -170.9059 25.745942 33.835 -169.1038 25.932508 33.974 -167.4326 26.120426 34.126 -165.8550 26.309705 34.295 -164.3309 26.500356 34.482 -162.8186 26.692388 34.686 -161.2786 26.885812 34.907 -159.6761 27.080638 35.143 -157.9839 27.276876 35.392 -156.1844 27.474535 35.649 -154.2697 27.673627 35.913 -152.2401 27.874161 36.177 -150.1024 28.076149 36.440 -147.8655 28.279600 36.696 -145.5391 28.484526 36.942 -143.1295 28.690937 37.174 -140.6388 28.898843 37.389 -138.0629 29.108256 37.585 -135.3908 29.319186 37.757 -132.6039 29.531645 37.905 -129.6749 29.745644 38.026 -126.5670 29.961193 38.120 -123.2314 30.178304 38.185 -119.6062 30.396989 38.223 -115.6124 30.617258 38.233 -111.1529 30.839123 38.216 -106.1122 31.062596 38.176 -100.3631 31.287688 38.114 -93.7858 31.514412 38.033 -86.3082 31.742778 37.937 -77.9686 31.972800 37.828 -68.9818 32.204488 37.711 -59.7545 32.437855 37.589 -50.8038 32.672913 37.464 -42.6015 32.909674 37.340 -35.4472 33.148151 37.219 -29.4417 33.388356 37.103 -24.5377 33.630302 36.991 -20.6096 33.874001 36.886 -17.5062 34.119466 36.786 -15.0804 34.366710 36.691 -13.2013 34.615745 36.600 -11.7578 34.866585 36.512 -10.6582 35.119243 36.424 -9.8275 35.373731 36.336 -9.2055 35.630064 36.246 -8.7441 35.888254 36.153 -8.4059 36.148315 36.056 -8.1617 36.410261 35.955 -7.9901 36.674104 35.848 -7.8748 36.939860 35.738 -7.8040 37.207542 35.623 -7.7687 37.477163 35.504 -7.7607 37.748738 35.385 -7.7721 38.022281 35.265 -7.7933 38.297806 35.147 -7.8127 38.575327 35.033 -7.8159 38.854860 34.927 -7.7854 39.136419 34.830 -7.7009 39.420017 34.745 -7.5394 39.705671 34.675 -7.2759 39.993395 34.622 -6.8835 40.283203 34.588 -6.3341 40.575112 34.575 -5.5988 40.869136 34.584 -4.6483 41.165290 34.616 -3.4542 41.463591 34.673 -1.9894 41.764053 34.754 -0.2305 42.066693 34.860 1.8402 42.371525 34.990 4.2317 42.678567 35.144 6.9404 42.987834 35.320 9.9473 43.299341 35.517 13.2145 43.613106 35.733 16.6855 43.929145 35.964 20.2871 44.247473 36.209 23.9366 44.568109 36.462 27.5491 44.891068 36.720 31.0474 45.216367 36.979 34.3687 45.544023 37.235 37.4690 45.874054 37.483 40.3231 46.206476 37.718 42.9227 46.541307 37.938 45.2727 46.878565 38.137 47.3872 47.218266 38.312 49.2867 47.560429 38.460 50.9956 47.905072 38.577 52.5405 48.252212 38.661 53.9497 48.601867 38.710 55.2527 48.954056 38.722 56.4807 49.308798 38.697 57.6670 49.666109 38.634 58.8483 50.026010 38.534 60.0663 50.388520 38.399 61.3697 50.753656 38.230 62.8181 51.121437 38.031 64.4868 51.491884 37.804 66.4742 51.865016 37.553 68.9133 52.240851 37.281 71.9881 52.619410 36.993 75.9564 53.000712 36.693 81.1761 53.384777 36.386 88.1149 53.771625 36.077 97.2830 54.161276 35.773 108.9532 54.553751 35.481 122.6122 54.949070 35.207 136.6683 55.347254 34.960 149.2497 55.748323 34.746 159.3636 56.152298 34.575 167.0245 56.559201 34.452 172.7006 56.969052 34.385 176.9034 57.381873 34.378 -179.9540 57.797686 34.432 -177.5697 58.216512 34.548 -175.7308 58.638373 34.724 -174.2888 59.063291 34.956 -173.1400 59.491288 35.238 -172.2119 59.922386 35.564 -171.4540 60.356608 35.927 -170.8313 60.793977 36.321 -170.3199 61.234515 36.740 -169.9039 61.678246 37.178 -169.5735 62.125192 37.631 -169.3229 62.575377 38.095 -169.1489 63.028824 38.568 -169.0497 63.485557 39.046 -169.0242 63.945599 39.527 -169.0714 64.408975 40.011 -169.1902 64.875709 40.497 -169.3793 65.345825 40.982 -169.6368 65.819348 41.468 -169.9606 66.296302 41.954 -170.3472 66.776713 42.439 -170.7924 67.260604 42.924 -171.2903 67.748002 43.409 -171.8341 68.238932 43.893 -172.4153 68.733420 44.378 -173.0250 69.231490 44.863 -173.6543 69.733170 45.349 -174.2950 70.238485 45.836 -174.9409 70.747463 46.325 -175.5876 71.260128 46.814 -176.2339 71.776508 47.305 -176.8814 72.296630 47.798 -177.5346 72.820521 48.292 -178.2006 73.348209 48.787 -178.8885 73.879720 49.283 -179.6090 74.415083 49.779 179.6265 74.954326 50.274 178.8059 75.497475 50.768 177.9177 76.044561 51.259 176.9509 76.595612 51.746 175.8956 77.150655 52.228 174.7437 77.709720 52.704 173.4882 78.272837 53.173 172.1248 78.840034 53.633 170.6506 79.411342 54.083 169.0649 79.986789 54.521 167.3684 80.566406 54.948 165.5634 81.150224 55.361 163.6532 81.738272 55.759 161.6422 82.330581 56.143 159.5352 82.927182 56.511 157.3380 83.528107 56.863 155.0566 84.133386 57.197 152.6979 84.743051 57.515 150.2687 85.357134 57.816 147.7766 85.975667 58.100 145.2292 86.598682 58.367 142.6345 87.226212 58.617 140.0002 87.858289 58.851 137.3343 88.494946 59.070 134.6440 89.136217 59.274 131.9363 89.782135 59.464 129.2177 90.432733 59.640 126.4940 91.088046 59.804 123.7703 91.748108 59.955 121.0516 92.412952 60.094 118.3425 93.082615 60.221 115.6471 93.757130 60.337 112.9696 94.436533 60.442 110.3143 95.120859 60.536 107.6851 95.810144 60.619 105.0864 96.504423 60.690 102.5225 97.203734 60.751 99.9978 97.908112 60.801 97.5168 98.617595 60.841 95.0839 99.332219 60.870 92.7035 100.052021 60.890 90.3798 100.777039 60.901 88.1163 101.507311 60.904 85.9167 102.242875 60.900 83.7839 102.983769 60.889 81.7205 103.730032 60.872 79.7284 104.481702 60.852 77.8093 105.238820 60.828 75.9645 106.001424 60.803 74.1948 106.769554 60.776 72.5006 107.543250 60.750 70.8821 108.322553 60.725 69.3387 109.107503 60.703 67.8699 109.898141 60.685 66.4742 110.694508 60.673 65.1497 111.496646 60.668 63.8933 112.304596 60.671 62.7015 113.118402 60.683 61.5695 113.938104 60.705 60.4916 114.763747 60.738 59.4613 115.595372 60.783 58.4715 116.433024 60.839 57.5146 117.276746 60.905 56.5833 118.126581 60.982 55.6702 118.982575 61.069 54.7689 119.844772 61.164 53.8741 120.713217 61.266 52.9815 121.587954 61.373 52.0886 122.469031 61.484 51.1948 123.356492 61.598 50.3011 124.250384 61.713 49.4106 125.150753 61.828 48.5287 126.057647 61.943 47.6621 126.971113 62.057 46.8197 127.891198 62.169 46.0112 128.817950 62.280 45.2477 129.751418 62.390 44.5400 130.691651 62.501 43.8990 131.638696 62.614 43.3334 132.592604 62.731 42.8495 133.553425 62.853 42.4493 134.521208 62.982 42.1300 135.496004 63.121 41.8823 136.477864 63.270 41.6907 137.466839 63.431 41.5339 138.462981 63.605 41.3858 139.466340 63.790 41.2177 140.476971 63.987 41.0003 141.494925 64.192 40.7062 142.520256 64.406 40.3118 143.553016 64.624 39.7988 144.593260 64.846 39.1546 145.641043 65.068 38.3726 146.696418 65.288 37.4513 147.759441 65.504 36.3942 148.830166 65.715 35.2079 149.908651 65.919 33.9018 150.994951 66.116 32.4867 152.089123 66.305 30.9744 153.191223 66.485 29.3761 154.301310 66.658 27.7027 155.419441 66.822 25.9639 156.545674 66.978 24.1678 157.680069 67.127 22.3212 158.822683 67.269 20.4293 159.973578 67.403 18.4958 161.132813 67.529 16.5233 162.300447 67.647 14.5132 163.476543 67.756 12.4664 164.661162 67.855 10.3836 165.854364 67.943 8.2657 167.056213 68.018 6.1145 168.266772 68.080 3.9324 169.486102 68.126 1.7233 170.714268 68.156 -0.5074 171.951334 68.169 -2.7529 173.197364 68.164 -5.0060 174.452424 68.141 -7.2584 175.716578 68.101 -9.5023 176.989893 68.045 -11.7307 178.272434 67.973 -13.9374 179.564270 67.887 -16.1172 180.865467 67.787 -18.2658 182.176092 67.676 -20.3793 183.496216 67.554 -22.4539 184.825905 67.423 -24.4847 186.165229 67.282 -26.4662 187.514259 67.132 -28.3910 188.873065 66.975 -30.2498 190.241717 66.810 -32.0313 191.620287 66.637 -33.7218 193.008847 66.457 -35.3058 194.407468 66.270 -36.7657 195.816225 66.077 -38.0833 197.235190 65.879 -39.2397 198.664438 65.677 -40.2180 200.104042 65.473 -41.0031 201.554078 65.270 -41.5842 203.014622 65.070 -41.9545 204.485750 64.875 -42.1115 205.967538 64.688 -42.0553 207.460064 64.514 -41.7861 208.963405 64.353 -41.2998 210.477640 64.211 -40.5828 212.002848 64.088 -39.6056 213.539108 63.987 -38.3148 215.086500 63.910 -36.6237 216.645105 63.859 -34.3982 218.215005 63.834 -31.4370 219.796281 63.834 -27.4429 221.389015 63.860 -21.9894 222.993292 63.909 -14.5128 224.609193 63.978 -4.4337 226.236804 64.066 8.3866 227.876209 64.169 22.8983 229.527494 64.285 36.8856 231.190745 64.409 48.4492 232.866048 64.540 57.0579 234.553491 64.676 63.1167 236.253163 64.814 67.2617 237.965150 64.952 70.0437 239.689544 65.089 71.8701 241.426433 65.223 73.0278 243.175909 65.353 73.7172 244.938062 65.477 74.0774 246.712984 65.593 74.2065 248.500768 65.700 74.1748 250.301507 65.797 74.0342 252.115295 65.882 73.8267 253.942226 65.953 73.5900 255.782396 66.009 73.3610 257.635901 66.051 73.1785 259.502837 66.078 73.0837 261.383301 66.092 73.1194 263.277392 66.095 73.3277 265.185209 66.091 73.7487 267.106850 66.086 74.4175 269.042417 66.084 75.3636 270.992009 66.092 76.6089 272.955729 66.117 78.1667 274.933678 66.166 80.0402 276.925961 66.244 82.2202 278.932681 66.357 84.6832 280.953942 66.509 87.3895 282.989850 66.703 90.2828 285.040511 66.940 93.2921 287.106032 67.219 96.3372 289.186521 67.539 99.3351 291.282086 67.895 102.2089 293.392836 68.285 104.8949 295.518881 68.703 107.3467 297.660333 69.145 109.5367 299.817302 69.606 111.4540 301.989902 70.082 113.1012 304.178245 70.570 114.4899 306.382446 71.065 115.6370 308.602620 71.566 116.5623 310.838882 72.069 117.2852 313.091348 72.573 117.8241 315.360137 73.075 118.1951 317.645367 73.576 118.4113 319.947156 74.072 118.4826 322.265625 74.563 118.4163 324.600895 75.048 118.2170 326.953086 75.526 117.8877 329.322323 75.995 117.4301 331.708729 76.455 116.8455 334.112427 76.904 116.1349 336.533543 77.343 115.3002 338.972204 77.769 114.3437 341.428536 78.182 113.2686 343.902668 78.582 112.0797 346.394729 78.967 110.7827 348.904848 79.338 109.3851 351.433156 79.694 107.8953 353.979786 80.035 106.3226 356.544869 80.360 104.6769 359.128540 80.670 102.9684 361.730934 80.965 101.2073 364.352185 81.244 99.4033 366.992431 81.509 97.5660 369.651810 81.759 95.7041 372.330459 81.995 93.8259 375.028519 82.216 91.9393 377.746130 82.424 90.0516 380.483434 82.618 88.1701 383.240574 82.799 86.3019 386.017693 82.969 84.4543 388.814937 83.127 82.6343 391.632450 83.275 80.8488 394.470380 83.413 79.1039 397.328875 83.544 77.4054 400.208084 83.668 75.7579 403.108157 83.788 74.1654 406.029245 83.903 72.6309 408.971500 84.016 71.1567 411.935076 84.127 69.7440 414.920127 84.239 68.3932 417.926810 84.350 67.1035 420.955280 84.463 65.8729 424.005695 84.579 64.6984 427.078215 84.696 63.5757 430.173000 84.817 62.4990 433.290211 84.940 61.4614 436.430010 85.065 60.4542 439.592562 85.193 59.4673 442.778031 85.323 58.4893 445.986583 85.454 57.5081 449.218386 85.585 56.5117 452.473607 85.715 55.4895 455.752418 85.842 54.4327 459.054987 85.965 53.3354 462.381489 86.082 52.1949 465.732096 86.192 51.0115 469.106983 86.294 49.7881 472.506325 86.388 48.5300 475.930301 86.474 47.2439 479.379088 86.550 45.9373 482.852867 86.618 44.6178 486.351817 86.678 43.2924 489.876123 86.731 41.9675 493.425968 86.778 40.6481 497.001536 86.820 39.3376 500.603014 86.859 38.0377 504.230589 86.894 36.7487 507.884452 86.928 35.4690 511.564792 86.960 34.1960 515.271802 86.990 32.9263 519.005673 87.020 31.6561 522.766602 87.047 30.3820 526.554785 87.072 29.1012 530.370418 87.093 27.8119 534.213700 87.110 26.5138 538.084833 87.120 25.2079 541.984018 87.123 23.8969 545.911457 87.117 22.5854 549.867357 87.100 21.2794 553.851922 87.073 19.9865 557.865362 87.032 18.7155 561.907884 86.979 17.4764 565.979700 86.911 16.2803 570.081022 86.829 15.1382 574.212064 86.732 14.0620 578.373042 86.621 13.0626 582.564171 86.496 12.1503 586.785671 86.358 11.3340 591.037762 86.207 10.6203 595.320665 86.047 10.0135 599.634604 85.878 9.5151 603.979804 85.702 9.1240 608.356491 85.522 8.8368 612.764893 85.339 8.6481 617.205240 85.156 8.5513 621.677763 84.974 8.5386 626.182696 84.796 8.6012 630.720274 84.622 8.7302 635.290733 84.455 8.9164 639.894312 84.295 9.1510 644.531250 84.144 9.4255 649.201789 84.002 9.7322 653.906173 83.869 10.0637 658.644647 83.747 10.4135 663.417457 83.634 10.7758 668.224854 83.531 11.1458 673.067086 83.437 11.5199 677.944408 83.352 11.8959 682.857073 83.275 12.2734 687.805336 83.205 12.6541 692.789457 83.142 13.0422 697.809695 83.084 13.4442 702.866312 83.030 13.8693 707.959571 82.981 14.3285 713.089738 82.935 14.8345 718.257080 82.893 15.4014 723.461867 82.853 16.0447 728.704370 82.816 16.7819 733.984862 82.781 17.6321 739.303619 82.748 18.6166 744.660918 82.718 19.7582 750.057038 82.689 21.0811 755.492260 82.662 22.6101 760.966869 82.638 24.3698 766.481148 82.615 26.3840 772.035387 82.596 28.6755 777.629873 82.581 31.2650 783.264900 82.570 34.1680 788.940760 82.564 37.3898 794.657750 82.565 40.9188 800.416168 82.574 44.7181 806.216313 82.591 48.7216 812.058489 82.618 52.8331 817.943000 82.655 56.9363 823.870152 82.702 60.9088 829.840255 82.759 64.6401 835.853619 82.824 68.0463 841.910559 82.896 71.0767 848.011390 82.973 73.7139 854.156430 83.055 75.9690 860.346000 83.140 77.8733 866.580422 83.226 79.4702 872.860020 83.313 80.8086 879.185124 83.401 81.9371 885.556062 83.490 82.9011 891.973166 83.579 83.7403 898.436771 83.671 84.4886 904.947215 83.765 85.1740 911.504835 83.863 85.8187 918.109975 83.964 86.4407 924.762978 84.070 87.0534 931.464192 84.181 87.6661 938.213966 84.297 88.2841 945.012651 84.418 88.9080 951.860602 84.546 89.5342 958.758176 84.680 90.1548 965.705733 84.819 90.7584 972.703635 84.963 91.3315 979.752246 85.110 91.8596 986.851935 85.261 92.3290 994.003071 85.412 92.7280 1001.206027 85.561 93.0481 1008.461179 85.708 93.2843 1015.768904 85.849 93.4357 1023.129584 85.982 93.5054 1030.543603 86.106 93.5007 1038.011347 86.219 93.4324 1045.533205 86.318 93.3145 1053.109569 86.402 93.1639 1060.740836 86.471 92.9998 1068.427401 86.523 92.8428 1076.169666 86.559 92.7150 1083.968035 86.578 92.6395 1091.822915 86.580 92.6392 1099.734713 86.567 92.7363 1107.703844 86.541 92.9514 1115.730723 86.503 93.3018 1123.815768 86.456 93.8007 1131.959400 86.403 94.4557 1140.162045 86.348 95.2688 1148.424129 86.293 96.2355 1156.746083 86.242 97.3448 1165.128342 86.199 98.5801 1173.571343 86.165 99.9193 1182.075524 86.143 101.3364 1190.641331 86.134 102.8024 1199.269209 86.141 104.2874 1207.959608 86.163 105.7614 1216.712981 86.199 107.1966 1225.529785 86.250 108.5685 1234.410479 86.314 109.8567 1243.355526 86.388 111.0450 1252.365393 86.472 112.1216 1261.440549 86.563 113.0780 1270.581467 86.658 113.9089 1279.788624 86.755 114.6118 1289.062500 86.852 115.1868 1298.403578 86.945 115.6362 1307.812346 87.031 115.9655 1317.289293 87.109 116.1830 1326.834914 87.176 116.3003 1336.449707 87.230 116.3316 1346.134173 87.268 116.2940 1355.888816 87.291 116.2067 1365.714145 87.296 116.0906 1375.610673 87.283 115.9680 1385.578915 87.252 115.8619 1395.619391 87.204 115.7971 1405.732624 87.138 115.7990 1415.919142 87.056 115.8942 1426.179476 86.959 116.1111 1436.514160 86.848 116.4783 1446.923734 86.725 117.0250 1457.408740 86.594 117.7795 1467.969724 86.457 118.7682 1478.607238 86.318 120.0131 1489.321836 86.182 121.5301 1500.114076 86.052 123.3269 1510.984521 85.933 125.4004 1521.933737 85.830 127.7348 1532.962297 85.748 130.3005 1544.070773 85.690 133.0544 1555.259747 85.659 135.9408 1566.529800 85.657 138.8949 1577.881521 85.686 141.8473 1589.315501 85.745 144.7292 1600.832336 85.833 147.4775 1612.432627 85.946 150.0391 1624.116978 86.083 152.3729 1635.886000 86.239 154.4514 1647.740304 86.410 156.2595 1659.680509 86.591 157.7926 1671.707238 86.779 159.0547 1683.821118 86.968 160.0556 1696.022780 87.155 160.8092 1708.312860 87.337 161.3320 1720.692000 87.509 161.6423 1733.160843 87.668 161.7593 1745.720041 87.812 161.7034 1758.370248 87.938 161.4952 1771.112124 88.043 161.1561 1783.946332 88.127 160.7079 1796.873543 88.187 160.1729 1809.894429 88.223 159.5735 1823.009670 88.233 158.9324 1836.219950 88.219 158.2715 1849.525956 88.179 157.6123 1862.928384 88.115 156.9751 1876.427931 88.028 156.3790 1890.025301 87.918 155.8422 1903.721204 87.787 155.3818 1917.516352 87.636 155.0146 1931.411466 87.467 154.7566 1945.407270 87.281 154.6229 1959.504493 87.079 154.6277 1973.703870 86.864 154.7834 1988.006142 86.637 155.0999 2002.412054 86.401 155.5837 2016.922357 86.158 156.2368 2031.537808 85.910 157.0564 2046.259169 85.660 158.0339 2061.087206 85.410 159.1560 2076.022694 85.164 160.4045 2091.066410 84.924 161.7578 2106.219139 84.692 163.1923 2121.481671 84.469 164.6835 2136.854802 84.259 166.2075 2152.339333 84.060 167.7421 2167.936071 83.875 169.2678 2183.645829 83.703 170.7686 2199.469427 83.543 172.2310 2215.407689 83.396 173.6448 2231.461446 83.260 175.0020 2247.631536 83.134 176.2963 2263.918800 83.016 177.5233 2280.324089 82.905 178.6803 2296.848258 82.797 179.7675 2313.492167 82.692 -179.2123 2330.256685 82.586 -178.2523 2347.142685 82.479 -177.3422 2364.151049 82.367 -176.4684 2381.282662 82.250 -175.6143 2398.538418 82.128 -174.7616 2415.919216 81.999 -173.8909 2433.425962 81.864 -172.9826 2451.059570 81.724 -172.0175 2468.820958 81.579 -170.9773 2486.711052 81.432 -169.8443 2504.730786 81.283 -168.6018 2522.881098 81.133 -167.2327 2541.162934 80.985 -165.7190 2559.577248 80.838 -164.0405 2578.125000 80.696 -162.1741 2596.807157 80.558 -160.0933 2615.624692 80.427 -157.7702 2634.578586 80.303 -155.1774 2653.669829 80.187 -152.2921 2672.899414 80.082 -149.1024 2692.268345 79.987 -145.6133 2711.777632 79.904 -141.8527 2731.428290 79.833 -137.8759 2751.221345 79.775 -133.7634 2771.157829 79.730 -129.6146 2791.238781 79.697 -125.5347 2811.465248 79.675 -121.6210 2831.838284 79.663 -117.9517 2852.358952 79.659 -114.5797 2873.028321 79.661 -111.5328 2893.847468 79.667 -108.8171 2914.817480 79.676 -106.4229 2935.939449 79.684 -104.3292 2957.214476 79.691 -102.5087 2978.643672 79.693 -100.9304 3000.228152 79.689 -99.5618 3021.969041 79.677 -98.3710 3043.867475 79.656 -97.3270 3065.924593 79.624 -96.4006 3088.141547 79.581 -95.5637 3110.519493 79.524 -94.7902 3133.059600 79.453 -94.0549 3155.763041 79.369 -93.3345 3178.631001 79.270 -92.6079 3201.664672 79.158 -91.8564 3224.865254 79.033 -91.0647 3248.233957 78.897 -90.2205 3271.771999 78.750 -89.3157 3295.480608 78.596 -88.3454 3319.361019 78.435 -87.3083 3343.414477 78.270 -86.2057 3367.642236 78.104 -85.0412 3392.045560 77.937 -83.8196 3416.625721 77.773 -82.5469 3441.383999 77.613 -81.2296 3466.321686 77.459 -79.8740 3491.440082 77.311 -78.4857 3516.740496 77.170 -77.0690 3542.224247 77.037 -75.6260 3567.892664 76.912 -74.1558 3593.747085 76.793 -72.6544 3619.788858 76.681 -71.1141 3646.019340 76.574 -69.5236 3672.439900 76.471 -67.8685 3699.051913 76.371 -66.1328 3725.856768 76.274 -64.3003 3752.855862 76.179 -62.3566 3780.050603 76.086 -60.2919 3807.442408 75.994 -58.1030 3835.032705 75.905 -55.7957 3862.822933 75.819 -53.3859 3890.814540 75.735 -50.8996 3919.008986 75.655 -48.3710 3947.407741 75.577 -45.8394 3976.012284 75.501 -43.3451 4004.824108 75.427 -40.9250 4033.844715 75.353 -38.6089 4063.075616 75.279 -36.4166 4092.518337 75.204 -34.3577 4122.174412 75.127 -32.4319 4152.045387 75.048 -30.6314 4182.132820 74.966 -28.9434 4212.438278 74.883 -27.3528 4242.963342 74.800 -25.8448 4273.709604 74.717 -24.4065 4304.678665 74.636 -23.0289 4335.872141 74.560 -21.7078 4367.291658 74.491 -20.4433 4398.938854 74.431 -19.2405 4430.815378 74.380 -18.1078 4462.922893 74.342 -17.0557 4495.263072 74.316 -16.0963 4527.837601 74.304 -15.2419 4560.648179 74.303 -14.5041 4593.696515 74.314 -13.8935 4626.984334 74.334 -13.4189 4660.513370 74.361 -13.0870 4694.285371 74.392 -12.9025 4728.302098 74.423 -12.8673 4762.565324 74.452 -12.9814 4797.076835 74.476 -13.2421 4831.838432 74.491 -13.6449 4866.851925 74.496 -14.1834 4902.119140 74.488 -14.8505 4937.641916 74.465 -15.6385 4973.422105 74.428 -16.5407 5009.461572 74.375 -17.5517 5045.762195 74.307 -18.6689 5082.325868 74.225 -19.8935 5119.154496 74.129 -21.2301 5156.250000 74.022 -22.6871 5193.614313 73.904 -24.2748 5231.249383 73.778 -26.0039 5269.157173 73.643 -27.8831 5307.339658 73.501 -29.9169 5345.798829 73.352 -32.1029 5384.536691 73.197 -34.4309 5423.555263 73.037 -36.8812 5462.856580 72.871 -39.4255 5502.442691 72.700 -42.0274 5542.315659 72.525 -44.6456 5582.477563 72.347 -47.2364 5622.930497 72.168 -49.7569 5663.676569 71.988 -52.1678 5704.717904 71.809 -54.4361 5746.056642 71.634 -56.5357 5787.694937 71.464 -58.4487 5829.634960 71.301 -60.1652 5871.878898 71.146 -61.6816 5914.428953 70.999 -63.0002 5957.287343 70.861 -64.1270 6000.456303 70.731 -65.0699 6043.938083 70.609 -65.8383 6087.734950 70.492 -66.4406 6131.849187 70.378 -66.8845 6176.283094 70.266 -67.1758 6221.038987 70.152 -67.3187 6266.119200 70.035 -67.3156 6311.526083 69.913 -67.1682 6357.262002 69.785 -66.8779 6403.329344 69.651 -66.4467 6449.730508 69.510 -65.8782 6496.467914 69.363 -65.1776 6543.543998 69.210 -64.3519 6590.961215 69.053 -63.4106 6638.722037 68.892 -62.3647 6686.828954 68.730 -61.2267 6735.284473 68.566 -60.0096 6784.091120 68.401 -58.7263 6833.251441 68.238 -57.3893 6882.767998 68.075 -56.0101 6932.643372 67.916 -54.5997 6982.880164 67.759 -53.1686 7033.480992 67.606 -51.7271 7084.448495 67.458 -50.2859 7135.785329 67.314 -48.8552 7187.494171 67.176 -47.4452 7239.577717 67.042 -46.0649 7292.038681 66.912 -44.7217 7344.879799 66.786 -43.4211 7398.103826 66.663 -42.1664 7451.713536 66.541 -40.9586 7505.711724 66.419 -39.7965 7560.101205 66.297 -38.6776 7614.884815 66.173 -37.5978 7670.065409 66.047 -36.5520 7725.645865 65.918 -35.5344 7781.629080 65.785 -34.5389 7838.017972 65.649 -33.5595 7894.815481 65.508 -32.5901 7952.024569 65.363 -31.6255 8009.648217 65.213 -30.6609 8067.689429 65.059 -29.6933 8126.151233 64.899 -28.7212 8185.036674 64.734 -27.7459 8244.348824 64.563 -26.7721 8304.090774 64.386 -25.8077 8364.265639 64.202 -24.8640 8424.876556 64.010 -23.9542 8485.926684 63.810 -23.0925 8547.419207 63.602 -22.2930 8609.357330 63.384 -21.5696 8671.744282 63.157 -20.9366 8734.583316 62.921 -20.4090 8797.877707 62.674 -20.0042 8861.630756 62.419 -19.7425 8925.845785 62.156 -19.6467 8990.526143 61.885 -19.7421 9055.675202 61.607 -20.0564 9121.296357 61.323 -20.6191 9187.393031 61.033 -21.4625 9253.968668 60.738 -22.6218 9321.026740 60.439 -24.1356 9388.570742 60.136 -26.0455 9456.604196 59.830 -28.3943 9525.130648 59.522 -31.2217 9594.153671 59.213 -34.5580 9663.676863 58.903 -38.4141 9733.703850 58.593 -42.7701 9804.238280 58.284 -47.5654 9875.283832 57.978 -52.6939 9946.844210 57.674 -58.0124 10018.923143 57.373 -63.3606 10091.524390 57.077 -68.5887 10164.651736 56.785 -73.5828 10238.308993 56.498 -78.2780 10312.500000 56.217 -82.6600 10387.228626 55.940 -86.7565 10462.498767 55.670 -90.6262 10538.314345 55.404 -94.3486 10614.679315 55.145 -98.0167 10691.597657 54.891 -101.7314 10769.073381 54.643 -105.5948 10847.110526 54.400 -109.7034 10925.713161 54.163 -114.1354 11004.885382 53.930 -118.9355 11084.631318 53.702 -124.0945 11164.955126 53.479 -129.5323 11245.860993 53.258 -135.0909 11327.353138 53.041 -140.5527 11409.435808 52.826 -145.6783 11492.113283 52.613 -150.2551 11575.389873 52.401 -154.1335 11659.269920 52.192 -157.2390 11743.757796 51.983 -159.5623 11828.857906 51.774 -161.1416 11914.574686 51.565 -162.0413 12000.912606 51.354 -162.3366 12087.876166 51.140 -162.1027 12175.469900 50.921 -161.4072 12263.698373 50.696 -160.3077 12352.566187 50.463 -158.8498 12442.077974 50.219 -157.0684 12532.238400 49.965 -154.9899 12623.052165 49.698 -152.6348 12714.524005 49.419 -150.0203 12806.658687 49.127 -147.1620 12899.461015 48.823 -144.0749 12992.935827 48.508 -140.7737 13087.087996 48.182 -137.2725 13181.922430 47.848 -133.5851 13277.444074 47.505 -129.7241 13373.657907 47.155 -125.6999 13470.568945 46.799 -121.5200 13568.182241 46.437 -117.1874 13666.502883 46.071 -112.6992 13765.535996 45.700 -108.0451 13865.286744 45.324 -103.2066 13965.760328 44.945 -98.1556 14066.961984 44.561 -92.8534 14168.896989 44.172 -87.2471 14271.570658 43.780 -81.2653 14374.988342 43.383 -74.8081 14479.155433 42.983 -67.7336 14584.077362 42.580 -59.8334 14689.759598 42.173 -50.7943 14796.207652 41.764 -40.1414 14903.427072 41.352 -27.1722 15011.423448 40.937 -10.9755 15120.202410 40.521 9.1337 15229.769630 40.102 32.3723 15340.130819 39.681 55.7474 15451.291730 39.259 76.2765 15563.258160 38.835 93.1882 15676.035944 38.409 107.1655 15789.630962 37.982 119.1099 15904.049137 37.553 129.7156 16019.296433 37.123 139.4534 16135.378859 36.693 148.6378 16252.302465 36.262 157.4846 16370.073348 35.831 166.1484 16488.697648 35.400 174.7465 16608.181548 34.970 -176.6296 16728.531278 34.541 -167.9069 16849.753112 34.114 -159.0271 16971.853368 33.689 -149.9460 17094.838414 33.267 -140.6328 17218.714660 32.849 -131.0701 17343.488565 32.437 -121.2568 17469.166632 32.030 -111.2112 17595.755415 31.629 -100.9713 17723.261512 31.236 -90.5953 17851.691571 30.852 -80.1572 17981.052287 30.478 -69.7405 18111.350404 30.113 -59.4302 18242.592715 29.760 -49.3042 18374.786062 29.417 -39.4269 18507.937336 29.085 -29.8457 18642.053479 28.765 -20.5913 18777.141484 28.456 -11.6804 18913.208391 28.157 -3.1189 19050.261296 27.869 5.0946 19188.307342 27.590 12.9662 19327.353727 27.319 20.5055 19467.407699 27.057 27.7247 19608.476560 26.803 34.6434 19750.567664 26.555 41.2909 19893.688419 26.315 47.7129 20037.846286 26.080 53.9766 20183.048781 25.852 60.1727 20329.303472 25.631 66.4153 20476.617985 25.418 72.8358 20625.000000 25.214 79.5735 20774.457252 25.020 86.7643 20924.997533 24.839 94.5304 21076.628691 24.672 102.9736 21229.358631 24.523 112.1715 21383.195315 24.393 122.1721 21538.146763 24.285 132.9854 21694.221053 24.202 144.5710 21851.426321 24.145 156.8346 22009.770764 24.117 169.6517
