1 //VoltageSource 7 //Lines 2.82842712474619 //Vrms F //Inverted 118 //position X 64 //position Y 0 //overall delay 1 //Power 8 //Ohms for Power level 1 //Subckts 27 //Lines Per Subckt L-Pad //Title subckt#0 //Var Name 0 0 //Var Val0 //Var Name 1 0 //Var Val1 dB //Var Name 2 5 //Var Val2 Attenuation setting for the L-Pad (in dB, positive value) R //Var Name 3 8 //Var Val3 Operating Impedance of the L-Pad (usually 8 ohms for purchaseable units) //Var Name 4 0 //Var Val4 //Var Name 5 0 //Var Val5 0 //stepmode 0 0 //stepmode 1 0 //stepmode 2 0 //stepmode 3 0 //stepmode 4 0 //stepmode 5 12 //Passives 20 //Lines Per Passive 0 //PartType 2 //RefDes //Part# 3.48 //Value -1 //ESR 10 //Rating 157 //position X 62 //position Y T //Is Horizontal 0 //StepMode 1 //0short/1val/2open 0 //Subckt#,-1 if none R*(1-(10^(-(dB+0.001)/20))) 10 F //Is HighSpec 0 //Specd component manuf tolerance 0 //Search tolerance for nom values 0 //ESR tolerance for search 0 //Tolerance of chosen part tol //vendor of part number 0 //PartType 3 //RefDes //Part# 10 //Value -1 //ESR 10 //Rating 160 //position X 65 //position Y F //Is Horizontal 1 //StepMode 1 //0short/1val/2open 0 //Subckt#,-1 if none R*(1/(1-10^(-(dB+0.001)/20)+1e-3)-1) 10 F //Is HighSpec 0 //Specd component manuf tolerance 0 //Search tolerance for nom values 0 //ESR tolerance for search 0 //Tolerance of chosen part tol //vendor of part number 1 //PartType 1 //RefDes //Part# 1.5E-5 //Value 0.05 //ESR 250 //Rating 130 //position X 62 //position Y T //Is Horizontal 1 //StepMode 1 //0short/1val/2open -1 //Subckt#,-1 if none //No Subckt equation1 //No Subckt equation2 F //Is HighSpec 0 //Specd component manuf tolerance 0 //Search tolerance for nom values 0 //ESR tolerance for search 0 //Tolerance of chosen part tol //vendor of part number 2 //PartType 1 //RefDes //Part# 0.0035 //Value 0.35 //ESR 300 //Rating 133 //position X 65 //position Y F //Is Horizontal 1 //StepMode 1 //0short/1val/2open -1 //Subckt#,-1 if none //No Subckt equation1 //No Subckt equation2 F //Is HighSpec 0 //Specd component manuf tolerance 0 //Search tolerance for nom values 0 //ESR tolerance for search 0 //Tolerance of chosen part tol //vendor of part number 2 //PartType 2 //RefDes //Part# 0.00033 //Value 0.13 //ESR 300 //Rating 136 //position X 62 //position Y T //Is Horizontal 1 //StepMode 1 //0short/1val/2open -1 //Subckt#,-1 if none //No Subckt equation1 //No Subckt equation2 F //Is HighSpec 0 //Specd component manuf tolerance 0 //Search tolerance for nom values 0 //ESR tolerance for search 0 //Tolerance of chosen part tol //vendor of part number 1 //PartType 2 //RefDes //Part# 2.7E-6 //Value 0.05 //ESR 250 //Rating 139 //position X 65 //position Y F //Is Horizontal 1 //StepMode 1 //0short/1val/2open -1 //Subckt#,-1 if none //No Subckt equation1 //No Subckt equation2 F //Is HighSpec 0 //Specd component manuf tolerance 0 //Search tolerance for nom values 0 //ESR tolerance for search 0 //Tolerance of chosen part tol //vendor of part number 1 //PartType 3 //RefDes //Part# 1E-6 //Value 0.05 //ESR 250 //Rating 130 //position X 77 //position Y T //Is Horizontal 1 //StepMode 1 //0short/1val/2open -1 //Subckt#,-1 if none //No Subckt equation1 //No Subckt equation2 F //Is HighSpec 0 //Specd component manuf tolerance 0 //Search tolerance for nom values 0 //ESR tolerance for search 0 //Tolerance of chosen part tol //vendor of part number 2 //PartType 3 //RefDes //Part# 0.00012 //Value 0.35 //ESR 300 //Rating 133 //position X 80 //position Y F //Is Horizontal 1 //StepMode 1 //0short/1val/2open -1 //Subckt#,-1 if none //No Subckt equation1 //No Subckt equation2 F //Is HighSpec 0 //Specd component manuf tolerance 0 //Search tolerance for nom values 0 //ESR tolerance for search 0 //Tolerance of chosen part tol //vendor of part number 2 //PartType 4 //RefDes //Part# 0.004 //Value 0.35 //ESR 300 //Rating 130 //position X 48 //position Y T //Is Horizontal 1 //StepMode 1 //0short/1val/2open -1 //Subckt#,-1 if none //No Subckt equation1 //No Subckt equation2 F //Is HighSpec 0 //Specd component manuf tolerance 0 //Search tolerance for nom values 0 //ESR tolerance for search 0 //Tolerance of chosen part tol //vendor of part number 1 //PartType 4 //RefDes //Part# 2.2E-5 //Value 0.05 //ESR 250 //Rating 133 //position X 51 //position Y F //Is Horizontal 1 //StepMode 1 //0short/1val/2open -1 //Subckt#,-1 if none //No Subckt equation1 //No Subckt equation2 F //Is HighSpec 0 //Specd component manuf tolerance 0 //Search tolerance for nom values 0 //ESR tolerance for search 0 //Tolerance of chosen part tol //vendor of part number 1 //PartType 5 //RefDes //Part# 2.2E-5 //Value 0.05 //ESR 250 //Rating 159 //position X 51 //position Y F //Is Horizontal 1 //StepMode 1 //0short/1val/2open -1 //Subckt#,-1 if none //No Subckt equation1 //No Subckt equation2 F //Is HighSpec 0 //Specd component manuf tolerance 0 //Search tolerance for nom values 0 //ESR tolerance for search 0 //Tolerance of chosen part tol //vendor of part number 0 //PartType 1 //RefDes //Part# 6.2 //Value -1 //ESR 10 //Rating 156 //position X 54 //position Y T //Is Horizontal 1 //StepMode 1 //0short/1val/2open -1 //Subckt#,-1 if none //No Subckt equation1 //No Subckt equation2 F //Is HighSpec 0 //Specd component manuf tolerance 0 //Search tolerance for nom values 0 //ESR tolerance for search 0 //Tolerance of chosen part tol //vendor of part number 10 //Grounds 3 //Lines Per Ground 160 //position X 68 //position Y -1 //Subckt#,-1 if none 164 //position X 64 //position Y -1 //Subckt#,-1 if none 121 //position X 66 //position Y -1 //Subckt#,-1 if none 133 //position X 68 //position Y -1 //Subckt#,-1 if none 139 //position X 68 //position Y -1 //Subckt#,-1 if none 133 //position X 83 //position Y -1 //Subckt#,-1 if none 164 //position X 79 //position Y -1 //Subckt#,-1 if none 133 //position X 54 //position Y -1 //Subckt#,-1 if none 164 //position X 50 //position Y -1 //Subckt#,-1 if none 153 //position X 54 //position Y -1 //Subckt#,-1 if none 7 //Wires 5 //Lines Per Wire 160 //End1 X 62 //End1 Y 164 //End2 X 62 //End2 Y -1 //Subckt#,-1 if none 121 //End1 X 62 //End1 Y 127 //End2 X 62 //End2 Y -1 //Subckt#,-1 if none 127 //End1 X 62 //End1 Y 127 //End2 X 77 //End2 Y -1 //Subckt#,-1 if none 139 //End1 X 62 //End1 Y 154 //End2 X 62 //End2 Y -1 //Subckt#,-1 if none 133 //End1 X 77 //End1 Y 164 //End2 X 77 //End2 Y -1 //Subckt#,-1 if none 127 //End1 X 48 //End1 Y 127 //End2 X 62 //End2 Y -1 //Subckt#,-1 if none 133 //End1 X 48 //End1 Y 164 //End2 X 48 //End2 Y -1 //Subckt#,-1 if none 3 //Texts 6 //Lines Per Text In 154 //position X 61 //position Y 8 //Size 8388608 //color 0 //Subckt#,-1 if none Out 160 //position X 61 //position Y 8 //Size 8388608 //color 0 //Subckt#,-1 if none Com 158 //position X 67 //position Y 8 //Size 8388608 //color 0 //Subckt#,-1 if none 3 //Drivers 34 //Lines Per Driver !Driver 0 1 //RefDes //Name //PartNumber 165 //position X 63 //position Y F //Inverted F //Muted 10 //Rating 0 //dBGain 5.52303430188256E-5 //Delay 0 //Xoffs 0 //Yoffs 0 //Zoffs 0 //Htilt 0 //Vtilt 0 //dia m.frd //FRD filename M.zma //ZMA filename F //Phase from Hilbert transform 100 //Lower Hilbert extrapolation frequency 20000 //Upper Hilbert extrapolation frequency 12 //Lower Extrapolation slope 12 //Upper Extrapolation slope F //Invert Hilbert phase if used 0 //Hilbert Delay to add F //get acoust info from a model //ACOUstic FRD filename //Vendor name 6.5 //Nominal Dia. 0 //rectang. Ht 0 //rectang. Wt // F //Z Phase from Hilbert transform **FRD 1 for driver 0 m.frd //frd filename * Measurement data measured by REW V5.20.9 * Source: ASIO M-Audio USB ASIO, Line In 1 Fast Track * Format: 512k Log Swept Sine, 1 sweep at -12,0 dBFS using a loopback as a timing reference * Dated: 21 juil. 2022 13:18:00 * REW Settings: * C-weighting compensation: Off * Target level: 75.0 dB * Note: 1.2m Delay 3,5800 ms (1,228 m, 4 ft 0,3 in) relative to Loopback from 2: Analog 1/2 Fast Track to 2: Line In 2 Fast Track with no timing offset * Measurement: M * Smoothing: Psychoacoustic * Frequency Step: 96 ppo * Start Frequency: 199.95117 Hz * * Freq(Hz) SPL(dB) Phase(degrees) 199.951172 62.006 178.1685 201.400101 62.518 173.3590 202.859528 63.049 168.0399 204.329529 63.597 162.1976 205.810181 64.157 155.8274 207.301559 64.727 148.9347 208.803757 65.302 141.5365 210.316833 65.882 133.6634 211.840881 66.463 125.3588 213.375961 67.044 116.6796 214.922165 67.625 107.6954 216.479584 68.202 98.4858 218.048279 68.777 89.1392 219.628342 69.347 79.7479 221.219864 69.912 70.4056 222.822922 70.471 61.2023 224.437592 71.024 52.2217 226.063965 71.571 43.5373 227.702118 72.111 35.2099 229.352142 72.643 27.2864 231.014130 73.167 19.7985 232.688156 73.683 12.7633 234.374313 74.191 6.1835 236.072693 74.689 0.0491 237.783371 75.178 -5.6609 239.506454 75.657 -10.9764 241.242020 76.126 -15.9346 242.990158 76.584 -20.5764 244.750961 77.032 -24.9460 246.524521 77.468 -29.0878 248.310944 77.894 -33.0447 250.110306 78.308 -36.8572 251.922714 78.710 -40.5618 253.748245 79.101 -44.1904 255.587006 79.480 -47.7698 257.439087 79.848 -51.3210 259.304596 80.204 -54.8604 261.183624 80.549 -58.3984 263.076263 80.883 -61.9415 264.982635 81.207 -65.4918 266.902802 81.521 -69.0477 268.836884 81.825 -72.6053 270.784973 82.121 -76.1581 272.747192 82.408 -79.6984 274.723633 82.689 -83.2173 276.714386 82.963 -86.7058 278.719574 83.232 -90.1548 280.739288 83.497 -93.5558 282.773651 83.758 -96.9012 284.822754 84.017 -100.1846 286.886688 84.275 -103.4009 288.965576 84.533 -106.5473 291.059540 84.790 -109.6224 293.168671 85.048 -112.6274 295.293091 85.307 -115.5653 297.432892 85.567 -118.4418 299.588226 85.828 -121.2648 301.759155 86.088 -124.0442 303.945831 86.349 -126.7921 306.148346 86.608 -129.5220 308.366821 86.864 -132.2490 310.601379 87.117 -134.9884 312.852112 87.364 -137.7558 315.119171 87.605 -140.5661 317.402649 87.837 -143.4329 319.702667 88.061 -146.3680 322.019379 88.273 -149.3810 324.352875 88.473 -152.4785 326.703278 88.660 -155.6646 329.070709 88.834 -158.9399 331.455292 88.992 -162.3026 333.857147 89.136 -165.7480 336.276428 89.263 -169.2693 338.713226 89.374 -172.8571 341.167694 89.468 -176.5001 343.639923 89.545 179.8143 346.130066 89.604 176.1007 348.638275 89.646 172.3750 351.164642 89.670 168.6551 353.709320 89.675 164.9603 356.272430 89.661 161.3120 358.854126 89.629 157.7338 361.454529 89.577 154.2515 364.073792 89.505 150.8931 366.712006 89.414 147.6884 369.369354 89.302 144.6692 372.045959 89.171 141.8679 374.741943 89.020 139.3167 377.457489 88.850 137.0466 380.192688 88.661 135.0852 382.947723 88.456 133.4550 385.722717 88.235 132.1708 388.517822 88.003 131.2382 391.333191 87.762 130.6516 394.168945 87.517 130.3927 397.025269 87.273 130.4302 399.902283 87.038 130.7209 402.800140 86.818 131.2109 405.718994 86.619 131.8395 408.658997 86.448 132.5425 411.620300 86.309 133.2571 414.603058 86.204 133.9264 417.607452 86.134 134.5032 420.633606 86.096 134.9534 423.681702 86.085 135.2578 426.751862 86.098 135.4124 429.844269 86.129 135.4277 432.959106 86.175 135.3271 436.096497 86.233 135.1432 439.256622 86.303 134.9152 442.439667 86.385 134.6844 445.645752 86.484 134.4910 448.875092 86.601 134.3696 452.127838 86.742 134.3469 455.404144 86.911 134.4387 458.704193 87.111 134.6486 462.028168 87.344 134.9670 465.376221 87.607 135.3721 468.748535 87.899 135.8308 472.145294 88.216 136.3013 475.566650 88.551 136.7361 479.012817 88.898 137.0853 482.483948 89.252 137.2996 485.980225 89.607 137.3337 489.501831 89.957 137.1484 493.048950 90.299 136.7124 496.621796 90.630 136.0031 500.220520 90.946 135.0071 503.845337 91.246 133.7198 507.496399 91.528 132.1443 511.173920 91.790 130.2911 514.878113 92.031 128.1760 518.609131 92.251 125.8199 522.367188 92.449 123.2469 526.152466 92.625 120.4838 529.965210 92.778 117.5589 533.805542 92.909 114.5013 537.673706 93.016 111.3406 541.569885 93.102 108.1055 545.494324 93.164 104.8248 549.447205 93.205 101.5258 553.428711 93.223 98.2354 557.439087 93.220 94.9794 561.478516 93.195 91.7830 565.547241 93.149 88.6710 569.645447 93.082 85.6681 573.773315 92.994 82.7993 577.931091 92.886 80.0894 582.119019 92.758 77.5635 586.337280 92.611 75.2468 590.586121 92.445 73.1631 594.865723 92.261 71.3350 599.176392 92.062 69.7816 603.518250 91.850 68.5179 607.891602 91.627 67.5524 612.296631 91.399 66.8863 616.733582 91.171 66.5117 621.202698 90.951 66.4109 625.704163 90.745 66.5565 630.238281 90.564 66.9114 634.805237 90.418 67.4307 639.405273 90.313 68.0628 644.038696 90.256 68.7529 648.705688 90.251 69.4449 653.406494 90.296 70.0843 658.141357 90.387 70.6207 662.910522 90.517 71.0096 667.714233 90.677 71.2140 672.552795 90.857 71.2047 677.426392 91.050 70.9613 682.335327 91.248 70.4716 687.279785 91.444 69.7315 692.260071 91.632 68.7444 697.276489 91.808 67.5201 702.329224 91.970 66.0753 707.418579 92.113 64.4315 712.544800 92.237 62.6147 717.708191 92.340 60.6554 722.908997 92.421 58.5864 728.147522 92.479 56.4432 733.423950 92.514 54.2628 738.738647 92.527 52.0826 744.091858 92.517 49.9398 749.483826 92.485 47.8700 754.914917 92.434 45.9066 760.385315 92.365 44.0789 765.895386 92.281 42.4110 771.445374 92.184 40.9200 777.035583 92.080 39.6151 782.666321 91.973 38.4959 788.337830 91.869 37.5524 794.050476 91.772 36.7645 799.804504 91.690 36.1030 805.600220 91.626 35.5312 811.437927 91.584 35.0077 817.317932 91.564 34.4884 823.240540 91.567 33.9306 829.206055 91.590 33.2956 835.214844 91.628 32.5516 841.267151 91.676 31.6754 847.363342 91.729 30.6538 853.503662 91.781 29.4841 859.688477 91.827 28.1733 865.918152 91.862 26.7368 872.192932 91.885 25.1974 878.513184 91.891 23.5829 884.879272 91.881 21.9239 891.291443 91.852 20.2521 897.750122 91.805 18.5981 904.255615 91.742 16.9897 910.808228 91.662 15.4506 917.408325 91.568 13.9990 924.056274 91.463 12.6469 930.752380 91.348 11.3999 937.497009 91.228 10.2571 944.290527 91.105 9.2115 951.133240 90.982 8.2513 958.025574 90.862 7.3604 964.967834 90.748 6.5206 971.960388 90.641 5.7124 979.003601 90.542 4.9174 986.097839 90.450 4.1191 993.243530 90.366 3.3048 1000.440979 90.287 2.4661 1007.690613 90.212 1.6002 1014.992737 90.137 0.7097 1022.347778 90.060 -0.1970 1029.756104 89.978 -1.1060 1037.218140 89.890 -1.9987 1044.734253 89.794 -2.8534 1052.304810 89.687 -3.6458 1059.930298 89.571 -4.3513 1067.610962 89.445 -4.9467 1075.347290 89.310 -5.4122 1083.139648 89.168 -5.7335 1090.988525 89.024 -5.9031 1098.894287 88.880 -5.9218 1106.857300 88.742 -5.7992 1114.878052 88.615 -5.5536 1122.956909 88.505 -5.2109 1131.094360 88.414 -4.8034 1139.290771 88.348 -4.3668 1147.546509 88.306 -3.9378 1155.862061 88.290 -3.5517 1164.237915 88.295 -3.2391 1172.674438 88.320 -3.0244 1181.172119 88.360 -2.9244 1189.731323 88.409 -2.9479 1198.352661 88.465 -3.0959 1207.036377 88.522 -3.3628 1215.783081 88.577 -3.7380 1224.593140 88.630 -4.2076 1233.467041 88.678 -4.7559 1242.405273 88.721 -5.3678 1251.408203 88.758 -6.0292 1260.476440 88.790 -6.7286 1269.610352 88.817 -7.4568 1278.810425 88.839 -8.2071 1288.077271 88.858 -8.9753 1297.411255 88.872 -9.7582 1306.812866 88.882 -10.5539 1316.282593 88.888 -11.3600 1325.820923 88.890 -12.1746 1335.428345 88.887 -12.9944 1345.105469 88.879 -13.8158 1354.852661 88.865 -14.6345 1364.670532 88.847 -15.4459 1374.559448 88.823 -16.2455 1384.520020 88.795 -17.0290 1394.552856 88.761 -17.7926 1404.658325 88.723 -18.5328 1414.837036 88.681 -19.2464 1425.089478 88.635 -19.9299 1435.416260 88.584 -20.5792 1445.817871 88.530 -21.1899 1456.294922 88.473 -21.7562 1466.847778 88.412 -22.2715 1477.477173 88.349 -22.7291 1488.183594 88.284 -23.1219 1498.967529 88.218 -23.4438 1509.829712 88.154 -23.6904 1520.770508 88.094 -23.8589 1531.790649 88.039 -23.9501 1542.890625 87.994 -23.9676 1554.071045 87.960 -23.9185 1565.332520 87.941 -23.8134 1576.675537 87.939 -23.6658 1588.100830 87.955 -23.4918 1599.608887 87.991 -23.3095 1611.200317 88.047 -23.1381 1622.875732 88.122 -22.9974 1634.635742 88.214 -22.9075 1646.480957 88.321 -22.8873 1658.411987 88.439 -22.9545 1670.429565 88.567 -23.1252 1682.534180 88.698 -23.4126 1694.726562 88.831 -23.8264 1707.007202 88.962 -24.3725 1719.376831 89.086 -25.0519 1731.836182 89.202 -25.8613 1744.385742 89.306 -26.7916 1757.026245 89.397 -27.8291 1769.758423 89.473 -28.9559 1782.582764 89.533 -30.1505 1795.500122 89.576 -31.3890 1808.511108 89.603 -32.6470 1821.616333 89.615 -33.9002 1834.816528 89.613 -35.1263 1848.112305 89.598 -36.3063 1861.504517 89.573 -37.4249 1874.993774 89.541 -38.4720 1888.580811 89.503 -39.4420 1902.266235 89.462 -40.3343 1916.050781 89.422 -41.1523 1929.935303 89.385 -41.9032 1943.920410 89.353 -42.5965 1958.006836 89.326 -43.2433 1972.195312 89.308 -43.8558 1986.486694 89.298 -44.4462 2000.881592 89.297 -45.0265 2015.380859 89.304 -45.6080 2029.985107 89.320 -46.2015 2044.695190 89.343 -46.8167 2059.511963 89.373 -47.4627 2074.436035 89.409 -48.1473 2089.468262 89.448 -48.8771 2104.609375 89.490 -49.6576 2119.860352 89.533 -50.4921 2135.221680 89.575 -51.3825 2150.694336 89.615 -52.3286 2166.279053 89.652 -53.3281 2181.976807 89.684 -54.3769 2197.788330 89.709 -55.4689 2213.714355 89.728 -56.5966 2229.755859 89.739 -57.7507 2245.913574 89.741 -58.9208 2262.188477 89.734 -60.0953 2278.581299 89.718 -61.2617 2295.092773 89.693 -62.4069 2311.723877 89.659 -63.5176 2328.475586 89.616 -64.5806 2345.348633 89.567 -65.5841 2362.343994 89.512 -66.5179 2379.462402 89.452 -67.3745 2396.705078 89.392 -68.1500 2414.072510 89.332 -68.8448 2431.565918 89.276 -69.4637 2449.186035 89.227 -70.0165 2466.933838 89.187 -70.5170 2484.810303 89.158 -70.9826 2502.816162 89.141 -71.4326 2520.952637 89.136 -71.8871 2539.220459 89.142 -72.3651 2557.620605 89.158 -72.8829 2576.154297 89.182 -73.4529 2594.822266 89.212 -74.0829 2613.625488 89.244 -74.7753 2632.564941 89.276 -75.5278 2651.641602 89.307 -76.3340 2670.856445 89.335 -77.1845 2690.210693 89.361 -78.0683 2709.705078 89.382 -78.9744 2729.340820 89.401 -79.8926 2749.118652 89.418 -80.8155 2769.039795 89.435 -81.7383 2789.105469 89.451 -82.6597 2809.316406 89.469 -83.5815 2829.673828 89.490 -84.5079 2850.178711 89.513 -85.4455 2870.832275 89.539 -86.4014 2891.635498 89.567 -87.3828 2912.589600 89.597 -88.3965 2933.695312 89.628 -89.4474 2954.954102 89.658 -90.5391 2976.366943 89.688 -91.6725 2997.934814 89.714 -92.8469 3019.659180 89.738 -94.0598 3041.540771 89.757 -95.3068 3063.581055 89.771 -96.5828 3085.781006 89.779 -97.8816 3108.141846 89.783 -99.1970 3130.664795 89.780 -100.5229 3153.350830 89.773 -101.8536 3176.201416 89.760 -103.1844 3199.217529 89.743 -104.5114 3222.400391 89.722 -105.8322 3245.751221 89.697 -107.1452 3269.271240 89.669 -108.4502 3292.961670 89.638 -109.7475 3316.823730 89.604 -111.0380 3340.858887 89.568 -112.3224 3365.068115 89.530 -113.6015 3389.452881 89.488 -114.8750 3414.014160 89.444 -116.1420 3438.753418 89.396 -117.4009 3463.672119 89.345 -118.6490 3488.771240 89.290 -119.8831 3514.052246 89.232 -121.0995 3539.516602 89.170 -122.2947 3565.165283 89.105 -123.4647 3591.000000 89.036 -124.6062 3617.021973 88.964 -125.7158 3643.232422 88.890 -126.7908 3669.632812 88.814 -127.8286 3696.224365 88.736 -128.8273 3723.008789 88.657 -129.7849 3749.987305 88.579 -130.7004 3777.161377 88.501 -131.5735 3804.532227 88.425 -132.4043 3832.101318 88.352 -133.1948 3859.870361 88.282 -133.9473 3887.840576 88.218 -134.6658 3916.013428 88.159 -135.3552 3944.390381 88.107 -136.0214 3972.973145 88.063 -136.6710 4001.762939 88.027 -137.3110 4030.761475 87.999 -137.9485 4059.969971 87.980 -138.5905 4089.390137 87.969 -139.2435 4119.023438 87.966 -139.9138 4148.871582 87.971 -140.6067 4178.936035 87.983 -141.3269 4209.218262 88.000 -142.0786 4239.720215 88.023 -142.8647 4270.442871 88.050 -143.6876 4301.388184 88.081 -144.5486 4332.557617 88.114 -145.4484 4363.953125 88.149 -146.3864 4395.576172 88.185 -147.3611 4427.428223 88.221 -148.3699 4459.511230 88.258 -149.4097 4491.826660 88.294 -150.4767 4524.376465 88.329 -151.5667 4557.162109 88.365 -152.6755 4590.185059 88.401 -153.8000 4623.447266 88.437 -154.9375 4656.950684 88.475 -156.0869 4690.696777 88.514 -157.2485 4724.687500 88.556 -158.4241 4758.924316 88.601 -159.6172 4793.409668 88.649 -160.8320 4828.144531 88.699 -162.0740 4863.131348 88.753 -163.3489 4898.371582 88.809 -164.6621 4933.867188 88.866 -166.0188 4969.620117 88.924 -167.4235 5005.631836 88.982 -168.8792 5041.904785 89.039 -170.3882 5078.440430 89.093 -171.9514 5115.240723 89.145 -173.5684 5152.308105 89.192 -175.2373 5189.644043 89.234 -176.9552 5227.250488 89.271 -178.7178 5265.129395 89.301 179.4806 5303.282715 89.324 177.6465 5341.712402 89.339 175.7871 5380.420410 89.347 173.9110 5419.409180 89.346 172.0266 5458.680664 89.338 170.1428 5498.236328 89.322 168.2681 5538.078613 89.300 166.4104 5578.209961 89.271 164.5773 5618.631836 89.236 162.7748 5659.346680 89.196 161.0078 5700.356445 89.153 159.2802 5741.663574 89.107 157.5938 5783.270020 89.060 155.9493 5825.177734 89.013 154.3464 5867.389160 88.967 152.7832 5909.906738 88.923 151.2568 5952.732422 88.883 149.7639 5995.868164 88.847 148.2996 6039.316895 88.816 146.8589 6083.080078 88.792 145.4363 6127.160645 88.774 144.0256 6171.560547 88.763 142.6207 6216.282227 88.760 141.2151 6261.328125 88.764 139.8026 6306.700195 88.775 138.3770 6352.401367 88.794 136.9321 6398.433594 88.819 135.4629 6444.799316 88.851 133.9645 6491.500977 88.888 132.4325 6538.541016 88.930 130.8635 6585.921875 88.976 129.2546 6633.645996 89.026 127.6040 6681.716309 89.079 125.9097 6730.134766 89.134 124.1711 6778.904297 89.191 122.3878 6828.026855 89.249 120.5598 6877.505371 89.307 118.6873 6927.342773 89.367 116.7706 6977.541016 89.426 114.8101 7028.103027 89.485 112.8059 7079.031738 89.544 110.7583 7130.329102 89.603 108.6667 7181.998535 89.661 106.5312 7234.042480 89.717 104.3512 7286.463379 89.772 102.1262 7339.264160 89.825 99.8560 7392.447266 89.876 97.5405 7446.016113 89.924 95.1804 7499.973145 89.968 92.7771 7554.320801 90.009 90.3325 7609.062500 90.045 87.8496 7664.200684 90.076 85.3323 7719.738770 90.102 82.7852 7775.679199 90.124 80.2136 7832.024902 90.140 77.6230 7888.778809 90.151 75.0190 7945.944336 90.158 72.4065 8003.523926 90.161 69.7893 8061.520996 90.162 67.1700 8119.937988 90.161 64.5498 8178.778320 90.158 61.9275 8238.044922 90.156 59.3005 8297.741211 90.154 56.6641 8357.870117 90.154 54.0120 8418.434570 90.155 51.3370 8479.438477 90.157 48.6315 8540.883789 90.161 45.8877 8602.774414 90.164 43.0990 8665.113281 90.167 40.2601 8727.904297 90.167 37.3680 8791.150391 90.164 34.4225 8854.854492 90.155 31.4260 8919.020508 90.140 28.3843 8983.651367 90.117 25.3062 9048.750977 90.084 22.2032 9114.322266 90.040 19.0895 9180.368164 89.985 15.9811 9246.892578 89.918 12.8950 9313.899414 89.840 9.8489 9381.391602 89.750 6.8590 9449.373047 89.650 3.9404 9517.846680 89.541 1.1061 9586.817383 89.426 -1.6351 9656.287109 89.305 -4.2778 9726.260742 89.183 -6.8212 9796.741211 89.062 -9.2686 9867.732422 88.946 -11.6276 9939.238281 88.839 -13.9097 10011.261719 88.743 -16.1290 10083.807617 88.662 -18.3021 10156.878906 88.599 -20.4464 10230.479492 88.555 -22.5798 10304.613281 88.531 -24.7196 10379.285156 88.528 -26.8822 10454.498047 88.545 -29.0829 10530.255859 88.583 -31.3357 10606.562500 88.638 -33.6532 10683.421875 88.710 -36.0469 10760.837891 88.797 -38.5275 10838.815430 88.897 -41.1047 10917.358398 89.007 -43.7885 10996.469727 89.125 -46.5868 11076.154297 89.248 -49.5074 11156.416992 89.375 -52.5571 11237.260742 89.502 -55.7406 11318.690430 89.628 -59.0610 11400.709961 89.750 -62.5192 11483.324219 89.867 -66.1138 11566.537109 89.977 -69.8408 11650.352539 90.079 -73.6941 11734.775391 90.171 -77.6652 11819.810547 90.253 -81.7439 11905.461914 90.324 -85.9192 11991.733398 90.385 -90.1791 12078.630859 90.434 -94.5121 12166.157227 90.473 -98.9069 12254.318359 90.502 -103.3534 12343.118164 90.522 -107.8433 12432.561523 90.533 -112.3694 12522.653320 90.536 -116.9263 12613.397461 90.531 -121.5098 12704.799805 90.519 -126.1169 12796.864258 90.500 -130.7455 12889.595703 90.476 -135.3937 12982.999023 90.445 -140.0602 13077.079102 90.409 -144.7440 13171.840820 90.368 -149.4446 13267.289062 90.323 -154.1616 13363.429688 90.274 -158.8956 13460.266602 90.221 -163.6478 13557.805664 90.165 -168.4208 13656.050781 90.107 -173.2178 13755.007812 90.048 -178.0431 13854.682617 89.987 177.0979 13955.079102 89.925 172.1993 14056.203125 89.862 167.2550 14158.060547 89.799 162.2582 14260.655273 89.736 157.2025 14363.994141 89.671 152.0817 14468.082031 89.605 146.8899 14572.923828 89.537 141.6223 14678.525391 89.467 136.2756 14784.891602 89.393 130.8478 14892.029297 89.314 125.3386 14999.943359 89.229 119.7509 15108.638672 89.136 114.0895 15218.122070 89.035 108.3624 15328.398438 88.923 102.5803 15439.474609 88.800 96.7562 15551.355469 88.664 90.9050 15664.046875 88.515 85.0430 15777.554688 88.352 79.1875 15891.885742 88.174 73.3558 16007.044922 87.981 67.5648 16123.038086 87.774 61.8306 16239.872070 87.553 56.1680 16357.552734 87.319 50.5908 16476.085938 87.072 45.1116 16595.478516 86.814 39.7417 16715.736328 86.547 34.4921 16836.865234 86.271 29.3743 16958.873047 85.991 24.3997 17081.763672 85.707 19.5813 17205.544922 85.424 14.9342 17330.222656 85.144 10.4757 17455.804688 84.871 6.2266 17582.296875 84.609 2.2102 17709.705078 84.361 -1.5470 17838.037109 84.133 -5.0167 17967.298828 83.927 -8.1697 18097.498047 83.747 -10.9784 18228.640625 83.595 -13.4197 18360.732422 83.471 -15.4781 18493.781250 83.374 -17.1497 18627.794922 83.302 -18.4453 18762.779297 83.252 -19.3931 18898.742188 83.220 -20.0375 19035.689453 83.201 -20.4369 19173.630859 83.191 -20.6566 19312.570312 83.186 -20.7604 19452.517578 83.185 -20.8000 19593.478516 83.184 -20.8114 19735.460938 83.184 -20.8136 19878.472656 83.184 -20.8138 **END FRD 1 for driver 0 **ZMA Data for driver 0 1.029 8.377 -1.701 1.059 8.377 -1.701 1.091 8.377 -1.701 1.122 8.377 -1.701 1.155 8.377 -1.701 1.189 8.377 -1.701 1.224 8.377 -1.701 1.260 8.377 -1.701 1.297 8.377 -1.701 1.335 8.215 -0.381 1.374 8.215 -0.381 1.414 8.215 -0.381 1.456 8.215 -0.381 1.498 8.215 -0.381 1.542 8.215 -0.381 1.587 8.215 -0.381 1.634 8.215 -0.381 1.682 8.215 -0.381 1.731 8.215 -0.381 1.782 8.215 -0.381 1.834 8.215 -0.381 1.888 8.215 -0.381 1.943 8.215 -0.381 2.000 8.138 0.336 2.059 8.138 0.336 2.119 8.138 0.336 2.181 8.138 0.336 2.245 8.138 0.336 2.311 8.138 0.336 2.378 8.138 0.336 2.448 8.138 0.336 2.520 8.138 0.336 2.594 8.138 0.336 2.670 8.150 0.201 2.748 8.150 0.201 2.828 8.150 0.201 2.911 8.150 0.201 2.997 8.150 0.201 3.084 8.150 0.201 3.175 8.150 0.201 3.268 8.150 0.201 3.364 8.153 0.413 3.462 8.153 0.413 3.564 8.153 0.413 3.668 8.153 0.413 3.775 8.153 0.413 3.886 8.153 0.413 4.000 8.159 0.405 4.117 8.159 0.405 4.238 8.159 0.405 4.362 8.159 0.405 4.490 8.159 0.405 4.621 8.159 0.405 4.757 8.160 0.539 4.896 8.160 0.539 5.040 8.160 0.539 5.187 8.160 0.539 5.339 8.163 0.587 5.496 8.163 0.587 5.657 8.163 0.587 5.823 8.163 0.587 5.993 8.159 0.730 6.169 8.159 0.730 6.350 8.159 0.730 6.536 8.159 0.730 6.727 8.165 0.802 6.924 8.165 0.802 7.127 8.165 0.802 7.336 8.162 0.890 7.551 8.162 0.890 7.772 8.162 0.890 8.000 8.162 0.959 8.234 8.162 0.959 8.476 8.162 0.959 8.724 8.153 1.010 8.980 8.153 1.010 9.243 8.153 1.010 9.514 8.146 1.091 9.792 8.146 1.091 10.079 8.144 1.132 10.375 8.144 1.132 10.679 8.143 1.239 10.992 8.143 1.239 11.314 8.149 1.288 11.645 8.149 1.288 11.986 8.150 1.361 12.338 8.150 1.361 12.699 8.160 1.389 13.071 8.160 1.389 13.454 8.157 1.451 13.849 8.157 1.451 14.254 8.161 1.514 14.672 8.156 1.586 15.102 8.156 1.586 15.545 8.163 1.683 16.000 8.165 1.753 16.469 8.165 1.753 16.951 8.173 1.847 17.448 8.173 1.869 17.959 8.175 1.961 18.486 8.175 1.961 19.027 8.180 2.012 19.585 8.186 2.153 20.159 8.187 2.186 20.749 8.192 2.253 21.357 8.191 2.331 21.983 8.195 2.424 22.627 8.196 2.511 23.290 8.199 2.611 23.973 8.201 2.690 24.675 8.205 2.782 25.398 8.209 2.842 26.143 8.209 2.917 26.909 8.209 3.001 27.697 8.206 3.076 28.509 8.207 3.161 29.344 8.208 3.294 30.204 8.213 3.402 31.089 8.217 3.483 32.000 8.219 3.567 32.938 8.216 3.648 33.903 8.211 3.739 34.896 8.210 3.855 35.919 8.216 3.958 36.971 8.225 4.030 38.055 8.234 4.074 39.170 8.237 4.135 40.317 8.241 4.197 41.499 8.248 4.298 42.715 8.265 4.448 43.967 8.286 4.595 45.255 8.300 4.743 46.581 8.308 4.911 47.946 8.314 5.108 49.351 8.320 5.323 50.797 8.327 5.504 52.285 8.331 5.640 53.817 8.329 5.771 55.394 8.325 5.897 57.018 8.325 5.983 58.688 8.334 6.095 60.408 8.345 6.166 62.178 8.359 6.248 64.000 8.372 6.341 65.875 8.392 6.488 67.806 8.413 6.661 69.792 8.436 6.845 71.838 8.451 7.052 73.943 8.458 7.286 76.109 8.455 7.566 78.339 8.447 7.818 80.635 8.437 7.936 82.998 8.433 7.997 85.430 8.443 8.071 87.933 8.469 8.188 90.510 8.503 8.408 93.162 8.529 8.736 95.892 8.537 9.195 98.701 8.536 9.557 101.594 8.524 9.833 104.571 8.517 10.065 107.635 8.521 10.247 110.789 8.550 10.432 114.035 8.592 10.677 117.377 8.634 11.143 120.816 8.653 11.726 124.356 8.645 12.258 128.000 8.637 12.526 131.751 8.662 12.688 135.611 8.734 13.022 139.585 8.795 13.523 143.675 8.831 14.191 147.885 8.840 14.763 152.219 8.849 15.134 156.679 8.905 15.375 161.270 8.998 15.842 165.995 9.070 16.618 170.860 9.093 17.325 175.866 9.127 17.739 181.019 9.215 18.039 186.324 9.333 18.680 191.783 9.422 19.631 197.403 9.474 20.230 203.187 9.587 20.602 209.141 9.762 21.341 215.269 9.891 22.303 221.577 10.004 22.887 228.070 10.209 23.332 234.753 10.451 24.179 241.632 10.647 24.965 248.712 10.928 25.423 256.000 11.298 25.913 263.501 11.673 26.477 271.223 12.125 26.420 279.170 12.649 26.216 287.350 13.243 25.553 295.770 13.878 23.949 304.437 14.493 21.156 313.358 14.604 16.690 322.540 13.939 13.245 331.991 13.036 12.765 341.719 12.539 14.738 351.732 12.369 17.445 362.039 12.690 20.329 372.647 13.258 21.960 383.567 13.963 22.792 394.806 14.651 23.094 406.375 15.724 22.637 418.282 16.776 20.913 430.539 17.952 17.442 443.155 19.007 12.869 456.140 19.695 5.877 469.506 18.961 -1.868 483.264 17.144 -6.344 497.424 15.312 -6.925 512.000 14.284 -5.291 527.003 13.749 -3.536 542.445 13.543 -2.037 558.340 13.437 -1.646 574.701 13.190 -1.291 591.541 12.799 -0.002 608.874 12.841 1.822 626.715 13.034 2.482 645.080 13.138 2.276 663.982 13.169 1.780 683.438 13.121 1.162 703.464 12.819 1.252 724.077 12.716 2.164 745.294 12.718 2.751 767.133 12.620 3.707 789.612 12.838 5.399 812.749 13.306 5.754 836.565 13.654 4.906 861.078 13.838 4.201 886.309 14.169 3.331 912.280 14.447 1.315 939.012 14.419 -1.337 966.527 13.986 -3.448 994.849 13.492 -4.155 1024.000 13.128 -4.063 1054.005 12.865 -3.799 1084.890 12.679 -3.525 1116.680 12.517 -3.260 1149.401 12.341 -3.029 1183.081 12.202 -2.516 1217.748 12.099 -2.169 1253.431 11.996 -1.849 1290.159 11.856 -1.416 1327.964 11.748 -0.794 1366.876 11.639 -0.118 1406.929 11.579 0.780 1448.155 11.560 1.658 1490.589 11.578 2.408 1534.266 11.613 3.184 1579.224 11.675 3.947 1625.499 11.782 4.584 1673.129 11.904 5.164 1722.156 12.059 5.569 1772.619 12.266 5.715 1824.561 12.439 5.515 1878.024 12.597 5.266 1933.055 12.887 4.986 1989.697 13.179 2.919 2048.000 12.962 0.189 2108.011 12.289 -0.837 2169.780 11.830 0.441 2233.360 11.684 1.772 2298.802 11.645 2.781 2366.162 11.648 3.617 2435.496 11.709 4.173 2506.862 11.725 4.321 2580.318 11.662 4.531 2655.927 11.577 5.146 2733.752 11.546 5.994 2813.857 11.588 6.970 2896.309 11.718 7.851 2981.178 11.921 8.275 3068.533 12.108 8.081 3158.448 12.194 7.556 3250.997 12.180 7.065 3346.259 12.113 6.772 3444.312 12.023 6.661 3545.238 11.919 6.740 3649.121 11.810 6.955 3756.049 11.697 7.343 3866.109 11.593 7.952 3979.395 11.526 8.751 4096.000 11.501 9.603 4216.022 11.504 10.465 4339.561 11.545 11.272 4466.720 11.603 11.929 4597.605 11.651 12.500 4732.325 11.687 13.123 4870.992 11.749 13.813 5013.723 11.834 14.436 5160.637 11.948 14.972 5311.855 12.062 15.168 5467.504 12.107 15.135 5627.714 12.047 15.328 5792.619 11.994 16.033 5962.355 12.005 16.959 6137.066 12.070 17.836 6316.896 12.171 18.643 6501.995 12.280 19.303 6692.518 12.376 19.914 6888.623 12.468 20.620 7090.476 12.595 21.373 7298.242 12.755 22.014 7512.097 12.929 22.517 7732.218 13.090 22.867 7958.790 13.228 23.193 8192.000 13.357 23.595 8432.044 13.511 24.046 8679.122 13.699 24.415 8933.439 13.911 24.576 9195.209 14.096 24.256 9464.649 14.087 23.717 9741.985 13.909 23.964 10027.447 13.866 25.009 10321.273 13.923 25.976 10623.710 13.972 27.038 10935.008 14.155 28.593 11255.428 14.543 29.619 11585.238 14.924 29.987 11924.711 15.203 29.957 12274.132 15.391 30.118 12633.791 15.592 30.509 13003.989 15.864 30.824 13385.035 16.079 30.847 13777.247 16.266 31.159 14180.951 16.491 31.765 14596.485 17.011 32.252 15024.194 17.613 31.158 15464.437 17.625 29.271 15917.579 17.206 28.650 16384.000 16.957 29.531 16864.088 16.918 30.640 17358.243 17.040 31.789 17866.879 17.247 32.870 18390.418 17.611 33.719 18929.299 17.975 34.064 19483.969 18.246 34.442 20054.893 18.765 34.729 20642.546 19.020 33.873 **END ZMA Data for driver 0 !Driver 1 2 //RefDes //Name //PartNumber 165 //position X 78 //position Y F //Inverted F //Muted 10 //Rating 0 //dBGain 0 //Delay 0 //Xoffs 0 //Yoffs 0 //Zoffs 0 //Htilt 0 //Vtilt 0 //dia a.frd //FRD filename a.zma //ZMA filename F //Phase from Hilbert transform 100 //Lower Hilbert extrapolation frequency 20000 //Upper Hilbert extrapolation frequency 12 //Lower Extrapolation slope 12 //Upper Extrapolation slope F //Invert Hilbert phase if used 0 //Hilbert Delay to add F //get acoust info from a model //ACOUstic FRD filename //Vendor name 6.5 //Nominal Dia. 0 //rectang. Ht 0 //rectang. Wt // F //Z Phase from Hilbert transform **FRD 1 for driver 1 a.frd //frd filename * Measurement data measured by REW V5.20.9 * Source: ASIO M-Audio USB ASIO, Line In 1 Fast Track * Format: 512k Log Swept Sine, 1 sweep at -12,0 dBFS using a loopback as a timing reference * Dated: 21 juil. 2022 13:22:30 * REW Settings: * C-weighting compensation: Off * Target level: 75.0 dB * Note: 1.2m Delay 3,2524 ms (1,116 m, 3 ft 7,9 in) relative to Loopback from 2: Analog 1/2 Fast Track to 2: Line In 2 Fast Track with no timing offset * Measurement: A * Smoothing: Psychoacoustic * Frequency Step: 96 ppo * Start Frequency: 1000.1221 Hz * * Freq(Hz) SPL(dB) Phase(degrees) 1000.122070 53.966 105.0449 1007.369385 53.862 104.4656 1014.669189 53.743 103.9080 1022.021912 53.607 103.4039 1029.427856 53.455 102.9903 1036.887573 53.285 102.7086 1044.401245 53.098 102.6030 1051.969360 52.895 102.7186 1059.592407 52.677 103.0989 1067.270630 52.447 103.7833 1075.004517 52.211 104.8042 1082.794434 51.977 106.1848 1090.640869 51.754 107.9368 1098.544067 51.556 110.0592 1106.504517 51.400 112.5381 1114.522705 51.306 115.3472 1122.598999 51.289 118.4493 1130.733765 51.364 121.7978 1138.927490 51.536 125.3394 1147.180664 51.801 129.0151 1155.493652 52.146 132.7625 1163.866821 52.555 136.5163 1172.300659 53.011 140.2101 1180.795654 53.497 143.7768 1189.352173 53.999 147.1505 1197.970703 54.506 150.2694 1206.651733 55.012 153.0774 1215.395630 55.510 155.5277 1224.202881 55.997 157.5854 1233.073975 56.470 159.2295 1242.009277 56.930 160.4531 1251.009399 57.374 161.2643 1260.074707 57.804 161.6835 1269.205688 58.221 161.7418 1278.402832 58.625 161.4774 1287.666626 59.017 160.9325 1296.997559 59.398 160.1495 1306.396118 59.770 159.1685 1315.862793 60.132 158.0249 1325.398071 60.485 156.7477 1335.002441 60.830 155.3588 1344.676392 61.164 153.8734 1354.420410 61.489 152.3004 1364.235107 61.802 150.6443 1374.120972 62.102 148.9061 1384.078369 62.389 147.0858 1394.108032 62.661 145.1833 1404.210327 62.918 143.2004 1414.385864 63.159 141.1408 1424.635132 63.382 139.0114 1434.958618 63.589 136.8219 1445.356934 63.780 134.5843 1455.830566 63.954 132.3128 1466.380127 64.112 130.0225 1477.006104 64.256 127.7287 1487.709106 64.386 125.4461 1498.489624 64.503 123.1876 1509.348267 64.610 120.9641 1520.285645 64.708 118.7831 1531.302246 64.798 116.6492 1542.398682 64.881 114.5631 1553.575562 64.959 112.5223 1564.833374 65.033 110.5214 1576.172852 65.102 108.5531 1587.594482 65.168 106.6093 1599.098877 65.229 104.6823 1610.686646 65.284 102.7670 1622.358398 65.334 100.8621 1634.114624 65.376 98.9717 1645.956055 65.412 97.1064 1657.883301 65.440 95.2845 1669.896973 65.462 93.5321 1681.997681 65.480 91.8830 1694.186157 65.499 90.3787 1706.462891 65.525 89.0667 1718.828613 65.565 88.0000 1731.283936 65.631 87.2343 1743.829590 65.735 86.8265 1756.466064 65.889 86.8309 1769.194092 66.103 87.2960 1782.014404 66.385 88.2597 1794.927612 66.736 89.7441 1807.934448 67.151 91.7506 1821.035522 67.623 94.2544 1834.231445 68.139 97.2008 1847.523071 68.685 100.5037 1860.911011 69.249 104.0467 1874.395996 69.821 107.6884 1887.978638 70.391 111.2710 1901.659668 70.952 114.6311 1915.439819 71.500 117.6122 1929.319946 72.029 120.0766 1943.300537 72.536 121.9134 1957.382446 73.020 123.0452 1971.566406 73.478 123.4288 1985.853149 73.908 123.0546 2000.243408 74.310 121.9419 2014.738037 74.684 120.1336 2029.337646 75.027 117.6903 2044.043091 75.341 114.6845 2058.854980 75.624 111.1951 2073.774414 75.877 107.3036 2088.801758 76.100 103.0905 2103.937988 76.293 98.6327 2119.184082 76.457 94.0019 2134.540527 76.592 89.2641 2150.008301 76.699 84.4780 2165.588135 76.778 79.6960 2181.280762 76.831 74.9639 2197.087158 76.859 70.3221 2213.008057 76.862 65.8055 2229.044434 76.842 61.4458 2245.197021 76.799 57.2720 2261.466553 76.734 53.3114 2277.854004 76.649 49.5908 2294.360352 76.544 46.1372 2310.986328 76.420 42.9779 2327.732666 76.281 40.1398 2344.600342 76.129 37.6483 2361.590332 75.968 35.5256 2378.703369 75.802 33.7881 2395.940430 75.640 32.4439 2413.302490 75.491 31.4896 2430.790283 75.364 30.9085 2448.404785 75.273 30.6689 2466.146973 75.229 30.7232 2484.017578 75.240 31.0098 2502.017822 75.313 31.4547 2520.148438 75.447 31.9758 2538.410400 75.637 32.4873 2556.804688 75.873 32.9048 2575.332275 76.144 33.1497 2593.994141 76.438 33.1537 2612.791260 76.743 32.8617 2631.724609 77.049 32.2332 2650.795166 77.348 31.2431 2670.003906 77.634 29.8816 2689.351807 77.903 28.1525 2708.839844 78.149 26.0724 2728.469238 78.372 23.6687 2748.240967 78.568 20.9785 2768.155762 78.735 18.0468 2788.214844 78.873 14.9259 2808.419434 78.980 11.6738 2828.770508 79.057 8.3534 2849.269043 79.104 5.0312 2869.916016 79.120 1.7759 2890.712646 79.108 -1.3439 2911.659912 79.071 -4.2615 2932.759033 79.012 -6.9152 2954.010986 78.936 -9.2514 2975.416992 78.852 -11.2274 2996.978027 78.767 -12.8152 3018.695312 78.693 -14.0034 3040.570068 78.643 -14.8001 3062.603271 78.630 -15.2329 3084.796143 78.664 -15.3491 3107.149902 78.755 -15.2139 3129.665527 78.903 -14.9067 3152.344482 79.106 -14.5168 3175.187744 79.358 -14.1382 3198.196533 79.645 -13.8636 3221.372070 79.958 -13.7790 3244.715576 80.283 -13.9589 3268.228027 80.610 -14.4627 3291.910889 80.932 -15.3325 3315.765381 81.241 -16.5921 3339.792725 81.533 -18.2479 3363.994141 81.803 -20.2902 3388.371094 82.051 -22.6957 3412.924561 82.272 -25.4303 3437.656006 82.468 -28.4518 3462.566650 82.637 -31.7125 3487.657715 82.779 -35.1621 3512.930664 82.894 -38.7491 3538.386719 82.983 -42.4229 3564.027344 83.047 -46.1352 3589.853760 83.087 -49.8403 3615.867432 83.104 -53.4967 3642.069580 83.099 -57.0672 3668.461426 83.076 -60.5194 3695.044678 83.036 -63.8267 3721.820557 82.983 -66.9682 3748.790283 82.920 -69.9294 3775.955566 82.851 -72.7034 3803.317627 82.781 -75.2903 3830.877930 82.715 -77.6986 3858.637939 82.658 -79.9447 3886.599121 82.614 -82.0527 3914.762939 82.587 -84.0533 3943.130859 82.580 -85.9827 3971.704346 82.594 -87.8803 4000.484863 82.628 -89.7859 4029.474121 82.678 -91.7372 4058.673340 82.741 -93.7669 4088.084229 82.811 -95.8999 4117.708008 82.883 -98.1511 4147.546387 82.950 -100.5244 4177.601074 83.009 -103.0122 4207.873535 83.054 -105.5958 4238.365723 83.083 -108.2468 4269.078613 83.093 -110.9294 4300.014160 83.083 -113.6030 4331.173828 83.054 -116.2251 4362.559082 83.007 -118.7550 4394.171875 82.944 -121.1563 4426.013672 82.869 -123.4001 4458.086426 82.788 -125.4669 4490.391602 82.705 -127.3486 4522.930664 82.629 -129.0490 4555.705566 82.565 -130.5837 4588.718262 82.520 -131.9794 4621.970215 82.500 -133.2716 4655.462891 82.508 -134.5022 4689.198242 82.545 -135.7164 4723.178223 82.609 -136.9590 4757.404297 82.698 -138.2713 4791.878418 82.805 -139.6880 4826.602539 82.926 -141.2352 4861.578125 83.053 -142.9282 4896.807129 83.183 -144.7720 4932.291504 83.310 -146.7607 4968.032715 83.431 -148.8793 5004.033203 83.546 -151.1056 5040.294434 83.653 -153.4128 5076.818359 83.752 -155.7723 5113.606934 83.847 -158.1569 5150.662109 83.940 -160.5435 5187.985840 84.033 -162.9156 5225.580078 84.129 -165.2647 5263.446777 84.231 -167.5916 5301.587891 84.340 -169.9055 5340.005371 84.458 -172.2231 5378.701172 84.583 -174.5663 5417.677246 84.713 -176.9591 5456.936035 84.845 -179.4249 5496.479004 84.977 178.0174 5536.308594 85.103 175.3552 5576.426758 85.221 172.5844 5616.835938 85.327 169.7101 5657.538086 85.420 166.7457 5698.535156 85.498 163.7120 5739.829102 85.562 160.6347 5781.422363 85.610 157.5417 5823.316895 85.646 154.4599 5865.515137 85.673 151.4128 5908.019043 85.692 148.4183 5950.831055 85.707 145.4865 5993.953125 85.723 142.6198 6037.387695 85.742 139.8126 6081.137207 85.766 137.0536 6125.203613 85.797 134.3268 6169.589355 85.836 131.6144 6214.296875 85.882 128.8998 6259.328125 85.933 126.1697 6304.686035 85.989 123.4158 6350.372559 86.047 120.6356 6396.390137 86.107 117.8322 6442.741211 86.167 115.0131 6489.427734 86.228 112.1885 6536.452637 86.292 109.3685 6583.818359 86.358 106.5611 6631.527344 86.431 103.7700 6679.582031 86.510 100.9932 6727.984863 86.599 98.2232 6776.738770 86.697 95.4469 6825.845703 86.804 92.6477 6875.308594 86.920 89.8071 6925.129883 87.043 86.9076 6975.312012 87.171 83.9341 7025.857910 87.302 80.8759 7076.770020 87.434 77.7272 7128.051270 87.565 74.4866 7179.704102 87.695 71.1566 7231.730957 87.822 67.7422 7284.135254 87.946 64.2489 7336.918945 88.067 60.6818 7390.085449 88.185 57.0444 7443.637207 88.301 53.3386 7497.576660 88.412 49.5645 7551.907227 88.520 45.7217 7606.631348 88.622 41.8103 7661.751953 88.719 37.8312 7717.271973 88.808 33.7874 7773.194336 88.890 29.6841 7829.521973 88.964 25.5278 7886.257812 89.029 21.3269 7943.404785 89.087 17.0896 8000.965820 89.139 12.8232 8058.944336 89.184 8.5335 8117.342773 89.223 4.2236 8176.164551 89.259 -0.1056 8235.412109 89.290 -4.4558 8295.088867 89.319 -8.8303 8355.198242 89.344 -13.2332 8415.743164 89.367 -17.6688 8476.727539 89.385 -22.1410 8538.153320 89.399 -26.6519 8600.024414 89.409 -31.2024 8662.343750 89.412 -35.7917 8725.114258 89.409 -40.4176 8788.339844 89.400 -45.0768 8852.023438 89.383 -49.7648 8916.168945 89.357 -54.4762 8980.779297 89.324 -59.2050 9045.857422 89.282 -63.9442 9111.407227 89.231 -68.6860 9177.432617 89.171 -73.4222 9243.936523 89.101 -78.1436 9310.921875 89.022 -82.8408 9378.392578 88.934 -87.5048 9446.352539 88.838 -92.1270 9514.804688 88.734 -96.7001 9583.752930 88.624 -101.2179 9653.201172 88.508 -105.6765 9723.152344 88.388 -110.0734 9793.610352 88.265 -114.4085 9864.579102 88.142 -118.6833 9936.061523 88.021 -122.9011 10008.062500 87.903 -127.0674 10080.584961 87.790 -131.1887 10153.632812 87.685 -135.2739 10227.209961 87.590 -139.3330 10301.320312 87.505 -143.3777 10375.967773 87.434 -147.4214 10451.156250 87.377 -151.4779 10526.889648 87.334 -155.5624 10603.171875 87.307 -159.6900 10680.006836 87.294 -163.8761 10757.398438 87.296 -168.1355 10835.350586 87.310 -172.4823 10913.868164 87.335 -176.9296 10992.954102 87.368 178.5108 11072.613281 87.408 173.8292 11152.849609 87.453 169.0178 11233.667969 87.498 164.0713 11315.071289 87.543 158.9869 11397.065430 87.584 153.7648 11479.653320 87.619 148.4081 11562.839844 87.647 142.9225 11646.628906 87.665 137.3168 11731.025391 87.673 131.6012 11816.033203 87.669 125.7884 11901.657227 87.651 119.8924 11987.901367 87.621 113.9277 12074.770508 87.576 107.9095 12162.269531 87.517 101.8529 12250.402344 87.444 95.7728 12339.173828 87.357 89.6829 12428.588867 87.256 83.5964 12518.651367 87.141 77.5251 12609.366211 87.014 71.4797 12700.739258 86.875 65.4692 12792.774414 86.725 59.5013 12885.476562 86.563 53.5825 12978.849609 86.393 47.7177 13072.899414 86.214 41.9097 13167.630859 86.027 36.1594 13263.048828 85.835 30.4664 13359.158203 85.638 24.8271 13455.963867 85.439 19.2367 13553.471680 85.239 13.6877 13651.685547 85.039 8.1711 13750.611328 84.842 2.6760 13850.253906 84.649 -2.8093 13950.618164 84.462 -8.2970 14051.709961 84.282 -13.7993 14153.534180 84.109 -19.3277 14256.096680 83.944 -24.8924 14359.402344 83.788 -30.5018 14463.456055 83.640 -36.1624 14568.264648 83.498 -41.8782 14673.832031 83.363 -47.6514 14780.165039 83.234 -53.4818 14887.268555 83.109 -59.3671 14995.147461 82.988 -65.3038 15103.808594 82.869 -71.2870 15213.256836 82.753 -77.3112 15323.498047 82.640 -83.3704 15434.538086 82.529 -89.4591 15546.382812 82.421 -95.5724 15659.038086 82.318 -101.7069 15772.509766 82.221 -107.8602 15886.803711 82.133 -114.0321 16001.925781 82.055 -120.2241 16117.882812 81.989 -126.4395 16234.679688 81.938 -132.6831 16352.323242 81.905 -138.9603 16470.818359 81.890 -145.2769 16590.171875 81.895 -151.6370 16710.390625 81.919 -158.0422 16831.480469 81.962 -164.4902 16953.449219 82.022 -170.9727 17076.300781 82.097 -177.4727 17200.042969 82.182 176.0352 17324.681641 82.276 169.5876 17450.222656 82.373 163.2336 17576.673828 82.470 157.0341 17704.041016 82.565 151.0603 17832.332031 82.654 145.3934 17961.552734 82.735 140.1187 18091.708984 82.807 135.3203 18222.808594 82.867 131.0750 18354.859375 82.917 127.4424 18487.867188 82.956 124.4575 18621.837891 82.984 122.1226 18756.779297 83.004 120.4028 18892.699219 83.017 119.2275 19029.603516 83.025 118.4967 19167.500000 83.029 118.0935 19306.396484 83.030 117.9033 19446.298828 83.031 117.8306 19587.214844 83.031 117.8096 19729.152344 83.031 117.8054 19872.117188 83.031 117.8052 **END FRD 1 for driver 1 **ZMA Data for driver 1 1.029 6.967 -2.158 1.059 6.967 -2.158 1.091 6.967 -2.158 1.122 6.967 -2.158 1.155 6.967 -2.158 1.189 6.967 -2.158 1.224 6.967 -2.158 1.260 6.967 -2.158 1.297 6.967 -2.158 1.335 6.809 -0.670 1.374 6.809 -0.670 1.414 6.809 -0.670 1.456 6.809 -0.670 1.498 6.809 -0.670 1.542 6.809 -0.670 1.587 6.809 -0.670 1.634 6.809 -0.670 1.682 6.809 -0.670 1.731 6.809 -0.670 1.782 6.809 -0.670 1.834 6.809 -0.670 1.888 6.809 -0.670 1.943 6.809 -0.670 2.000 6.735 0.126 2.059 6.735 0.126 2.119 6.735 0.126 2.181 6.735 0.126 2.245 6.735 0.126 2.311 6.735 0.126 2.378 6.735 0.126 2.448 6.735 0.126 2.520 6.735 0.126 2.594 6.735 0.126 2.670 6.749 -0.083 2.748 6.749 -0.083 2.828 6.749 -0.083 2.911 6.749 -0.083 2.997 6.749 -0.083 3.084 6.749 -0.083 3.175 6.749 -0.083 3.268 6.749 -0.083 3.364 6.750 0.082 3.462 6.750 0.082 3.564 6.750 0.082 3.668 6.750 0.082 3.775 6.750 0.082 3.886 6.750 0.082 4.000 6.756 -0.019 4.117 6.756 -0.019 4.238 6.756 -0.019 4.362 6.756 -0.019 4.490 6.756 -0.019 4.621 6.756 -0.019 4.757 6.752 0.072 4.896 6.752 0.072 5.040 6.752 0.072 5.187 6.752 0.072 5.339 6.755 0.030 5.496 6.755 0.030 5.657 6.755 0.030 5.823 6.755 0.030 5.993 6.748 0.119 6.169 6.748 0.119 6.350 6.748 0.119 6.536 6.748 0.119 6.727 6.753 0.095 6.924 6.753 0.095 7.127 6.753 0.095 7.336 6.748 0.142 7.551 6.748 0.142 7.772 6.748 0.142 8.000 6.750 0.122 8.234 6.750 0.122 8.476 6.750 0.122 8.724 6.744 0.162 8.980 6.744 0.162 9.243 6.744 0.162 9.514 6.744 0.183 9.792 6.744 0.183 10.079 6.741 0.189 10.375 6.741 0.189 10.679 6.742 0.205 10.992 6.742 0.205 11.314 6.742 0.182 11.645 6.742 0.182 11.986 6.743 0.211 12.338 6.743 0.211 12.699 6.744 0.202 13.071 6.744 0.202 13.454 6.742 0.245 13.849 6.742 0.245 14.254 6.743 0.232 14.672 6.740 0.257 15.102 6.740 0.257 15.545 6.743 0.241 16.000 6.740 0.266 16.469 6.740 0.266 16.951 6.745 0.252 17.448 6.742 0.269 17.959 6.747 0.281 18.486 6.747 0.281 19.027 6.741 0.274 19.585 6.743 0.283 20.159 6.744 0.298 20.749 6.743 0.286 21.357 6.743 0.308 21.983 6.744 0.295 22.627 6.742 0.313 23.290 6.744 0.309 23.973 6.743 0.322 24.675 6.745 0.342 25.398 6.744 0.354 26.143 6.747 0.376 26.909 6.746 0.379 27.697 6.747 0.411 28.509 6.749 0.407 29.344 6.750 0.415 30.204 6.751 0.410 31.089 6.752 0.416 32.000 6.751 0.425 32.938 6.751 0.436 33.903 6.751 0.468 34.896 6.751 0.488 35.919 6.750 0.502 36.971 6.748 0.523 38.055 6.748 0.524 39.170 6.748 0.513 40.317 6.750 0.532 41.499 6.750 0.538 42.715 6.749 0.557 43.967 6.749 0.578 45.255 6.750 0.601 46.581 6.750 0.628 47.946 6.752 0.645 49.351 6.750 0.644 50.797 6.751 0.651 52.285 6.753 0.654 53.817 6.756 0.678 55.394 6.758 0.694 57.018 6.758 0.712 58.688 6.759 0.736 60.408 6.760 0.752 62.178 6.763 0.775 64.000 6.764 0.798 65.875 6.761 0.828 67.806 6.760 0.838 69.792 6.761 0.856 71.838 6.764 0.883 73.943 6.767 0.919 76.109 6.766 0.947 78.339 6.766 0.970 80.635 6.766 1.002 82.998 6.768 1.027 85.430 6.769 1.045 87.933 6.771 1.055 90.510 6.771 1.079 93.162 6.772 1.116 95.892 6.771 1.152 98.701 6.773 1.185 101.594 6.775 1.232 104.571 6.777 1.280 107.635 6.777 1.310 110.789 6.777 1.335 114.035 6.776 1.358 117.377 6.776 1.394 120.816 6.778 1.428 124.356 6.781 1.457 128.000 6.783 1.485 131.751 6.784 1.527 135.611 6.786 1.591 139.585 6.787 1.640 143.675 6.787 1.683 147.885 6.788 1.721 152.219 6.787 1.755 156.679 6.789 1.786 161.270 6.792 1.830 165.995 6.795 1.888 170.860 6.797 1.937 175.866 6.799 1.988 181.019 6.800 2.043 186.324 6.800 2.107 191.783 6.800 2.163 197.403 6.799 2.203 203.187 6.801 2.245 209.141 6.805 2.318 215.269 6.808 2.397 221.577 6.811 2.468 228.070 6.812 2.530 234.753 6.815 2.596 241.632 6.817 2.665 248.712 6.821 2.736 256.000 6.823 2.806 263.501 6.826 2.869 271.223 6.827 2.944 279.170 6.830 3.025 287.350 6.832 3.112 295.770 6.837 3.196 304.437 6.842 3.274 313.358 6.846 3.361 322.540 6.849 3.440 331.991 6.852 3.529 341.719 6.857 3.622 351.732 6.861 3.717 362.039 6.867 3.807 372.647 6.871 3.905 383.567 6.876 4.012 394.806 6.881 4.114 406.375 6.887 4.227 418.282 6.892 4.336 430.539 6.897 4.451 443.155 6.904 4.549 456.140 6.911 4.648 469.506 6.918 4.761 483.264 6.927 4.897 497.424 6.936 5.024 512.000 6.945 5.133 527.003 6.955 5.247 542.445 6.963 5.372 558.340 6.972 5.483 574.701 6.985 5.598 591.541 6.996 5.716 608.874 7.006 5.831 626.715 7.016 5.945 645.080 7.027 6.074 663.982 7.037 6.199 683.438 7.048 6.315 703.464 7.061 6.434 724.077 7.074 6.550 745.294 7.085 6.658 767.133 7.095 6.754 789.612 7.106 6.864 812.749 7.117 6.998 836.565 7.126 7.134 861.078 7.133 7.259 886.309 7.140 7.393 912.280 7.148 7.525 939.012 7.159 7.657 966.527 7.170 7.796 994.849 7.179 7.949 1024.000 7.187 8.104 1054.005 7.197 8.286 1084.890 7.203 8.494 1116.680 7.209 8.705 1149.401 7.216 8.906 1183.081 7.225 9.119 1217.748 7.235 9.361 1253.431 7.246 9.625 1290.159 7.257 9.905 1327.964 7.269 10.202 1366.876 7.285 10.509 1406.929 7.303 10.840 1448.155 7.323 11.198 1490.589 7.347 11.577 1534.266 7.379 11.964 1579.224 7.416 12.366 1625.499 7.463 12.775 1673.129 7.519 13.156 1722.156 7.585 13.474 1772.619 7.653 13.709 1824.561 7.718 13.829 1878.024 7.772 13.861 1933.055 7.804 13.917 1989.697 7.825 14.143 2048.000 7.871 14.568 2108.011 7.956 14.888 2169.780 8.042 14.952 2233.360 8.104 14.915 2298.802 8.159 14.954 2366.162 8.221 14.982 2435.496 8.286 14.930 2506.862 8.338 14.745 2580.318 8.360 14.474 2655.927 8.342 14.265 2733.752 8.292 14.312 2813.857 8.244 14.748 2896.309 8.231 15.448 2981.178 8.266 16.223 3068.533 8.340 16.946 3158.448 8.442 17.516 3250.997 8.555 17.917 3346.259 8.668 18.153 3444.312 8.766 18.296 3545.238 8.850 18.438 3649.121 8.932 18.632 3756.049 9.023 18.857 3866.109 9.130 19.072 3979.395 9.246 19.155 4096.000 9.345 19.143 4216.022 9.428 19.214 4339.561 9.522 19.414 4466.720 9.653 19.602 4597.605 9.804 19.548 4732.325 9.911 19.294 4870.992 9.976 19.306 5013.723 10.098 19.677 5160.637 10.321 19.884 5311.855 10.581 19.545 5467.504 10.811 18.740 5627.714 10.980 17.660 5792.619 11.084 16.376 5962.355 11.077 15.004 6137.066 10.947 13.940 6316.896 10.770 13.620 6501.995 10.657 13.867 6692.518 10.636 14.377 6888.623 10.705 14.814 7090.476 10.831 14.956 7298.242 10.957 14.829 7512.097 11.128 14.544 7732.218 11.321 13.653 7958.790 11.389 11.962 8192.000 11.239 10.388 8432.044 10.978 9.427 8679.122 10.705 9.112 8933.439 10.442 9.239 9195.209 10.208 9.833 9464.649 10.035 10.757 9741.985 9.907 11.886 10027.447 9.837 13.266 10321.273 9.884 14.821 10623.710 10.048 16.097 10935.008 10.266 16.713 11255.428 10.497 16.634 11585.238 10.616 15.968 11924.711 10.609 15.240 12274.132 10.530 14.689 12633.791 10.357 14.252 13003.989 10.074 14.459 13385.035 9.813 15.776 13777.247 9.694 17.774 14180.951 9.722 19.834 14596.485 9.843 21.689 15024.194 10.030 23.306 15464.437 10.271 24.664 15917.579 10.544 25.729 16384.000 10.833 26.767 16864.088 11.279 28.088 17358.243 12.170 28.191 17866.879 12.976 24.489 18390.418 12.780 18.818 18929.299 11.733 16.595 19483.969 10.906 18.522 20054.893 10.676 21.615 20642.546 10.744 24.465 **END ZMA Data for driver 1 !Driver 2 3 //RefDes //Name //PartNumber 165 //position X 49 //position Y F //Inverted F //Muted 10 //Rating 0 //dBGain 0.000310855272873336 //Delay 0 //Xoffs 0 //Yoffs 0 //Zoffs 0 //Htilt 0 //Vtilt 0 //dia g.frd //FRD filename g.zma //ZMA filename F //Phase from Hilbert transform 100 //Lower Hilbert extrapolation frequency 20000 //Upper Hilbert extrapolation frequency 12 //Lower Extrapolation slope 12 //Upper Extrapolation slope F //Invert Hilbert phase if used 0 //Hilbert Delay to add F //get acoust info from a model //ACOUstic FRD filename //Vendor name 6.5 //Nominal Dia. 0 //rectang. Ht 0 //rectang. Wt // F //Z Phase from Hilbert transform **FRD 1 for driver 2 g.frd //frd filename * Measurement data measured by REW V5.20.9 * Source: ASIO M-Audio USB ASIO, Line In 1 Fast Track * Format: 512k Log Swept Sine, 1 sweep at -12,0 dBFS using a loopback as a timing reference * Dated: 21 juil. 2022 15:22:12 * REW Settings: * C-weighting compensation: Off * Target level: 75.0 dB * Note: 1.2m Delay 3,4378 ms (1,179 m, 3 ft 10,4 in) relative to Loopback from 2: Analog 1/2 Fast Track to 2: Line In 2 Fast Track with no timing offset 3,3533 ms * Measurement: G * Smoothing: Psychoacoustic * Frequency Step: 96 ppo * Start Frequency: 20.141602 Hz * * Freq(Hz) SPL(dB) Phase(degrees) 20.141602 61.938 -97.9529 20.287556 62.322 -97.2117 20.434568 62.702 -96.4658 20.582645 63.079 -95.7206 20.731796 63.452 -94.9816 20.882027 63.822 -94.2548 21.033346 64.188 -93.5462 21.185762 64.550 -92.8619 21.339283 64.908 -92.2083 21.493916 65.262 -91.5915 21.649670 65.612 -91.0178 21.806553 65.957 -90.4934 21.964573 66.297 -90.0240 22.123737 66.632 -89.6156 22.284056 66.963 -89.2737 22.445536 67.289 -89.0037 22.608185 67.609 -88.8108 22.772013 67.924 -88.6997 22.937029 68.234 -88.6751 23.103241 68.537 -88.7413 23.270657 68.835 -88.9024 23.439285 69.127 -89.1621 23.609137 69.413 -89.5239 23.780218 69.693 -89.9907 23.952539 69.966 -90.5652 24.126110 70.232 -91.2496 24.300938 70.492 -92.0459 24.477032 70.744 -92.9553 24.654402 70.990 -93.9787 24.833057 71.228 -95.1164 25.013008 71.459 -96.3681 25.194263 71.681 -97.7331 25.376831 71.896 -99.2100 25.560722 72.103 -100.7967 25.745945 72.302 -102.4905 25.932510 72.493 -104.2882 26.120428 72.674 -106.1856 26.309708 72.848 -108.1781 26.500359 73.013 -110.2605 26.692390 73.168 -112.4265 26.885815 73.315 -114.6696 27.080641 73.454 -116.9824 27.276878 73.583 -119.3569 27.474539 73.703 -121.7846 27.673630 73.814 -124.2562 27.874165 73.917 -126.7621 28.076153 74.011 -129.2921 28.279604 74.097 -131.8356 28.484529 74.175 -134.3816 28.690941 74.245 -136.9188 28.898848 74.307 -139.4357 29.108261 74.363 -141.9208 29.319191 74.413 -144.3622 29.531651 74.458 -146.7487 29.745649 74.498 -149.0685 29.961199 74.534 -151.3107 30.178310 74.569 -153.4646 30.396996 74.603 -155.5199 30.617264 74.637 -157.4673 30.839128 74.673 -159.2979 31.062601 74.714 -161.0040 31.287693 74.760 -162.5787 31.514416 74.814 -164.0164 31.742783 74.878 -165.3126 31.972803 74.953 -166.4642 32.204491 75.041 -167.4694 32.437859 75.143 -168.3279 32.672916 75.261 -169.0410 32.909679 75.395 -169.6113 33.148155 75.546 -170.0432 33.388359 75.714 -170.3424 33.630306 75.897 -170.5163 33.874004 76.096 -170.5734 34.119469 76.309 -170.5238 34.366711 76.534 -170.3789 34.615746 76.771 -170.1508 34.866585 77.017 -169.8531 35.119244 77.271 -169.4997 35.373734 77.531 -169.1055 35.630066 77.796 -168.6854 35.888256 78.064 -168.2550 36.148315 78.334 -167.8295 36.410259 78.605 -167.4242 36.674103 78.876 -167.0537 36.939857 79.145 -166.7324 37.207539 79.413 -166.4736 37.477161 79.678 -166.2898 37.748737 79.940 -166.1925 38.022282 80.198 -166.1919 38.297806 80.452 -166.2970 38.575329 80.701 -166.5154 38.854862 80.946 -166.8534 39.136421 81.186 -167.3157 39.420021 81.420 -167.9059 39.705673 81.649 -168.6259 39.993397 81.873 -169.4766 40.283207 82.091 -170.4575 40.575115 82.304 -171.5669 40.869141 82.511 -172.8023 41.165295 82.712 -174.1602 41.463596 82.908 -175.6361 41.764057 83.099 -177.2252 42.066696 83.284 -178.9221 42.371529 83.463 179.2792 42.678570 83.638 177.3846 42.987835 83.807 175.4002 43.299343 83.970 173.3320 43.613110 84.129 171.1862 43.929150 84.282 168.9684 44.247478 84.431 166.6839 44.568115 84.574 164.3378 44.891075 84.712 161.9347 45.216373 84.845 159.4789 45.544029 84.972 156.9740 45.874062 85.095 154.4234 46.206486 85.212 151.8300 46.541317 85.323 149.1966 46.878574 85.429 146.5254 47.218277 85.529 143.8185 47.560440 85.623 141.0782 47.905083 85.711 138.3064 48.252224 85.792 135.5051 48.601879 85.867 132.6767 48.954067 85.935 129.8235 49.308807 85.996 126.9482 49.666119 86.049 124.0539 50.026020 86.095 121.1440 50.388531 86.134 118.2224 50.753666 86.164 115.2934 51.121449 86.186 112.3619 51.491894 86.200 109.4330 51.865025 86.206 106.5126 52.240860 86.203 103.6067 52.619419 86.192 100.7220 53.000721 86.172 97.8656 53.384785 86.143 95.0449 53.771633 86.105 92.2675 54.161285 86.058 89.5415 54.553761 86.002 86.8751 54.949081 85.937 84.2764 55.347263 85.863 81.7543 55.748333 85.781 79.3169 56.152309 85.689 76.9728 56.559212 85.588 74.7303 56.969063 85.478 72.5974 57.381886 85.360 70.5821 57.797699 85.233 68.6917 58.216526 85.097 66.9333 58.638386 84.953 65.3134 59.063305 84.801 63.8378 59.491302 84.640 62.5117 59.922401 84.471 61.3393 60.356625 84.295 60.3242 60.793995 84.111 59.4689 61.234531 83.919 58.7748 61.678261 83.721 58.2425 62.125206 83.516 57.8710 62.575390 83.305 57.6585 63.028835 83.087 57.6017 63.485569 82.865 57.6963 63.945610 82.638 57.9365 64.408989 82.406 58.3155 64.875725 82.172 58.8252 65.345840 81.935 59.4563 65.819366 81.696 60.1986 66.296318 81.457 61.0410 66.776726 81.219 61.9713 67.260620 80.984 62.9770 67.748016 80.752 64.0447 68.238945 80.527 65.1609 68.733429 80.309 66.3119 69.231499 80.101 67.4839 69.733177 79.905 68.6634 70.238495 79.724 69.8372 70.747475 79.558 70.9927 71.260139 79.411 72.1181 71.776520 79.283 73.2022 72.296638 79.176 74.2350 72.820526 79.090 75.2073 73.348213 79.026 76.1114 73.879723 78.984 76.9403 74.415085 78.962 77.6887 74.954330 78.960 78.3520 75.497482 78.976 78.9271 76.044571 79.007 79.4118 76.595619 79.054 79.8049 77.150665 79.112 80.1064 77.709732 79.181 80.3168 78.272850 79.258 80.4374 78.840050 79.343 80.4703 79.411354 79.433 80.4178 79.986801 79.527 80.2827 80.566422 79.623 80.0681 81.150238 79.722 79.7772 81.738289 79.821 79.4132 82.330597 79.921 78.9793 82.927200 80.020 78.4788 83.528122 80.118 77.9145 84.133400 80.214 77.2892 84.743065 80.309 76.6058 85.357147 80.401 75.8665 85.975677 80.490 75.0736 86.598694 80.575 74.2293 87.226227 80.658 73.3355 87.858307 80.736 72.3940 88.494965 80.810 71.4068 89.136238 80.880 70.3757 89.782158 80.946 69.3025 90.432755 81.006 68.1892 91.088066 81.062 67.0378 91.748131 81.112 65.8506 92.412979 81.157 64.6299 93.082642 81.196 63.3782 93.757156 81.229 62.0981 94.436562 81.257 60.7924 95.120888 81.279 59.4640 95.810173 81.294 58.1159 96.504456 81.304 56.7513 97.203766 81.308 55.3734 97.908142 81.305 53.9854 98.617622 81.297 52.5906 99.332245 81.283 51.1924 100.052048 81.262 49.7942 100.777069 81.236 48.3988 101.507339 81.205 47.0044 102.242905 81.167 45.6147 102.983795 81.123 44.2338 103.730057 81.074 42.8658 104.481728 81.019 41.5157 105.238846 80.958 40.1884 106.001450 80.891 38.8897 106.769577 80.819 37.6259 107.543274 80.741 36.4039 108.322578 80.657 35.2317 109.107529 80.568 34.1179 109.898170 80.474 33.0722 110.694534 80.374 32.1054 111.496674 80.268 31.2293 112.304626 80.157 30.4568 113.118431 80.042 29.8020 113.938133 79.922 29.2799 114.763779 79.797 28.9065 115.595406 79.669 28.6984 116.433060 79.539 28.6729 117.276779 79.406 28.8476 118.126617 79.273 29.2396 118.982613 79.142 29.8658 119.844810 79.014 30.7419 120.713257 78.892 31.8818 121.587997 78.780 33.2974 122.469070 78.681 34.9978 123.356529 78.599 36.9884 124.250420 78.538 39.2707 125.150787 78.505 41.8416 126.057678 78.502 44.6929 126.971146 78.533 47.8113 127.891228 78.603 51.1778 128.817978 78.711 54.7681 129.751450 78.860 58.5531 130.691681 79.046 62.4990 131.638733 79.268 66.5681 132.592636 79.522 70.7200 133.553452 79.803 74.9123 134.521240 80.107 79.1019 135.496033 80.431 83.2460 136.477890 80.768 87.3029 137.466858 81.116 91.2334 138.462997 81.472 95.0009 139.466354 81.832 98.5727 140.476990 82.194 101.9196 141.494949 82.556 105.0169 142.520279 82.917 107.8441 143.553040 83.275 110.3849 144.593277 83.629 112.6272 145.641052 83.979 114.5628 146.696426 84.322 116.1873 147.759445 84.660 117.4992 148.830170 84.990 118.5005 149.908661 85.313 119.1955 150.994965 85.628 119.5906 152.089142 85.934 119.6945 153.191238 86.232 119.5170 154.301331 86.521 119.0692 155.419464 86.799 118.3633 156.545700 87.068 117.4121 157.680099 87.327 116.2287 158.822708 87.575 114.8267 159.973602 87.811 113.2198 161.132843 88.037 111.4220 162.300476 88.250 109.4472 163.476578 88.452 107.3095 164.661194 88.641 105.0233 165.854401 88.818 102.6027 167.056244 88.983 100.0622 168.266800 89.134 97.4163 169.486130 89.273 94.6793 170.714294 89.400 91.8657 171.951355 89.514 88.9893 173.197388 89.615 86.0638 174.452454 89.704 83.1024 175.716614 89.781 80.1172 176.989929 89.847 77.1196 178.272476 89.901 74.1199 179.564316 89.945 71.1273 180.865509 89.978 68.1499 182.176132 90.002 65.1943 183.496262 90.015 62.2663 184.825958 90.019 59.3709 186.165283 90.014 56.5125 187.514313 90.000 53.6949 188.873123 89.977 50.9222 190.241776 89.945 48.1988 191.620346 89.903 45.5298 193.008911 89.851 42.9211 194.407532 89.790 40.3804 195.816284 89.718 37.9163 197.235245 89.635 35.5393 198.664490 89.540 33.2614 200.104095 89.434 31.0960 201.554138 89.315 29.0577 203.014679 89.183 27.1622 204.485809 89.037 25.4255 205.967590 88.879 23.8636 207.460114 88.707 22.4918 208.963455 88.521 21.3242 210.477692 88.322 20.3728 212.002899 88.111 19.6471 213.539154 87.888 19.1534 215.086548 87.654 18.8940 216.645157 87.411 18.8674 218.215057 87.161 19.0671 219.796341 86.907 19.4826 221.389069 86.652 20.0988 222.993347 86.399 20.8966 224.609253 86.155 21.8536 226.236862 85.923 22.9443 227.876266 85.710 24.1415 229.527557 85.523 25.4164 231.190811 85.366 26.7404 232.866119 85.246 28.0848 234.553558 85.165 29.4222 236.253235 85.127 30.7271 237.965225 85.132 31.9755 239.689621 85.177 33.1460 241.426514 85.261 34.2195 243.175995 85.377 35.1793 244.938141 85.520 36.0112 246.713058 85.685 36.7031 248.500839 85.867 37.2451 250.301575 86.059 37.6296 252.115356 86.259 37.8508 253.942291 86.461 37.9049 255.782455 86.663 37.7900 257.635956 86.862 37.5061 259.502899 87.055 37.0551 261.383362 87.241 36.4405 263.277466 87.419 35.6678 265.185272 87.586 34.7440 267.106903 87.743 33.6777 269.042480 87.887 32.4787 270.992065 88.020 31.1580 272.955780 88.139 29.7276 274.933716 88.245 28.2005 276.925995 88.338 26.5901 278.932709 88.417 24.9104 280.953979 88.482 23.1755 282.989899 88.533 21.4000 285.040558 88.569 19.5983 287.106079 88.592 17.7849 289.186554 88.601 15.9740 291.282104 88.596 14.1794 293.392853 88.578 12.4144 295.518890 88.547 10.6915 297.660339 88.503 9.0219 299.817322 88.448 7.4155 301.989929 88.382 5.8806 304.178284 88.306 4.4235 306.382477 88.222 3.0479 308.602661 88.131 1.7551 310.838928 88.035 0.5439 313.091400 87.934 -0.5898 315.360199 87.832 -1.6529 317.645416 87.730 -2.6545 319.947205 87.630 -3.6062 322.265686 87.533 -4.5206 324.600952 87.439 -5.4120 326.953156 87.351 -6.2944 329.322388 87.268 -7.1818 331.708801 87.191 -8.0868 334.112488 87.118 -9.0203 336.533600 87.048 -9.9907 338.972260 86.981 -11.0038 341.428589 86.914 -12.0621 343.902710 86.845 -13.1646 346.394775 86.773 -14.3073 348.904907 86.696 -15.4827 351.433228 86.612 -16.6805 353.979858 86.520 -17.8878 356.544952 86.417 -19.0892 359.128632 86.303 -20.2672 361.731018 86.177 -21.4032 364.352264 86.038 -22.4768 366.992523 85.885 -23.4670 369.651917 85.718 -24.3521 372.330566 85.538 -25.1094 375.028625 85.343 -25.7162 377.746246 85.134 -26.1498 380.483551 84.912 -26.3881 383.240692 84.676 -26.4099 386.017822 84.429 -26.1968 388.815063 84.170 -25.7332 391.632568 83.903 -25.0088 394.470490 83.629 -24.0194 397.328979 83.353 -22.7684 400.208191 83.080 -21.2677 403.108276 82.815 -19.5381 406.029358 82.565 -17.6090 408.971619 82.340 -15.5173 411.935181 82.148 -13.3059 414.920227 81.997 -11.0210 417.926910 81.894 -8.7098 420.955383 81.845 -6.4183 424.005798 81.851 -4.1884 427.078308 81.910 -2.0573 430.173096 82.017 -0.0554 433.290314 82.167 1.7930 436.430115 82.352 3.4701 439.592682 82.565 4.9636 442.778137 82.797 6.2660 445.986694 83.044 7.3735 449.218506 83.300 8.2850 452.473724 83.560 9.0015 455.752533 83.822 9.5253 459.055115 84.081 9.8596 462.381622 84.337 10.0089 465.732239 84.586 9.9780 469.107117 84.828 9.7731 472.506470 85.062 9.4010 475.930450 85.286 8.8696 479.379242 85.500 8.1881 482.853027 85.704 7.3660 486.351990 85.898 6.4133 489.876282 86.080 5.3406 493.426117 86.252 4.1574 497.001678 86.414 2.8730 500.603149 86.566 1.4955 504.230713 86.707 0.0316 507.884583 86.838 -1.5131 511.564911 86.958 -3.1342 515.271912 87.067 -4.8280 519.005798 87.166 -6.5912 522.766724 87.252 -8.4204 526.554932 87.326 -10.3116 530.370544 87.386 -12.2598 534.213806 87.433 -14.2583 538.084961 87.465 -16.2992 541.984131 87.481 -18.3726 545.911560 87.481 -20.4673 549.867432 87.465 -22.5706 553.851990 87.432 -24.6685 557.865417 87.382 -26.7462 561.907959 87.314 -28.7883 565.979797 87.229 -30.7789 570.081116 87.126 -32.7018 574.212158 87.006 -34.5410 578.373108 86.869 -36.2809 582.564209 86.715 -37.9060 586.785706 86.545 -39.4020 591.037781 86.358 -40.7555 595.320679 86.156 -41.9547 599.634644 85.940 -42.9895 603.979858 85.709 -43.8519 608.356567 85.467 -44.5366 612.764954 85.214 -45.0406 617.205322 84.952 -45.3644 621.677856 84.682 -45.5107 626.182800 84.408 -45.4856 630.720398 84.133 -45.2975 635.290833 83.859 -44.9575 639.894409 83.589 -44.4791 644.531372 83.329 -43.8773 649.201904 83.081 -43.1686 653.906311 82.849 -42.3708 658.644775 82.638 -41.5024 663.417603 82.452 -40.5821 668.224976 82.294 -39.6290 673.067200 82.166 -38.6622 677.944519 82.070 -37.7005 682.857178 82.006 -36.7626 687.805420 81.975 -35.8663 692.789551 81.973 -35.0292 697.809814 82.000 -34.2675 702.866455 82.051 -33.5963 707.959717 82.122 -33.0293 713.089905 82.211 -32.5785 718.257263 82.312 -32.2538 723.462036 82.421 -32.0631 728.704529 82.536 -32.0116 733.985046 82.652 -32.1024 739.303833 82.767 -32.3360 744.661133 82.879 -32.7104 750.057251 82.984 -33.2214 755.492493 83.081 -33.8624 760.967102 83.168 -34.6251 766.481384 83.245 -35.4991 772.035645 83.309 -36.4730 777.630127 83.361 -37.5338 783.265137 83.399 -38.6677 788.940979 83.423 -39.8604 794.657959 83.434 -41.0971 800.416382 83.429 -42.3636 806.216553 83.411 -43.6459 812.058716 83.379 -44.9309 817.943237 83.333 -46.2070 823.870361 83.275 -47.4642 829.840454 83.205 -48.6943 835.853821 83.123 -49.8908 841.910767 83.031 -51.0489 848.011597 82.930 -52.1650 854.156616 82.819 -53.2366 860.346191 82.700 -54.2609 866.580627 82.573 -55.2350 872.860229 82.437 -56.1549 879.185364 82.294 -57.0150 885.556274 82.142 -57.8085 891.973389 81.982 -58.5269 898.437012 81.813 -59.1609 904.947449 81.636 -59.7009 911.505066 81.450 -60.1381 918.110229 81.258 -60.4652 924.763245 81.059 -60.6776 931.464478 80.856 -60.7744 938.214233 80.650 -60.7584 945.012939 80.444 -60.6372 951.860901 80.241 -60.4226 958.758484 80.044 -60.1306 965.706055 79.855 -59.7799 972.703979 79.678 -59.3916 979.752563 79.514 -58.9872 986.852234 79.365 -58.5880 994.003357 79.232 -58.2130 1001.206299 79.113 -57.8785 1008.461426 79.008 -57.5973 1015.769165 78.916 -57.3779 1023.129822 78.833 -57.2250 1030.543823 78.757 -57.1395 1038.011597 78.686 -57.1194 1045.533447 78.618 -57.1605 1053.109863 78.551 -57.2569 1060.741089 78.483 -57.4026 1068.427612 78.414 -57.5916 1076.169922 78.343 -57.8184 1083.968262 78.269 -58.0781 1091.823120 78.191 -58.3660 1099.734863 78.110 -58.6769 1107.703979 78.024 -59.0037 1115.730835 77.933 -59.3364 1123.815918 77.835 -59.6605 1131.959595 77.728 -59.9560 1140.162231 77.612 -60.1962 1148.424316 77.484 -60.3480 1156.746216 77.343 -60.3729 1165.128418 77.189 -60.2280 1173.571411 77.021 -59.8694 1182.075562 76.841 -59.2552 1190.641357 76.651 -58.3503 1199.269287 76.455 -57.1298 1207.959717 76.260 -55.5837 1216.713135 76.075 -53.7196 1225.529907 75.908 -51.5648 1234.410645 75.771 -49.1664 1243.355713 75.675 -46.5891 1252.365601 75.627 -43.9117 1261.440796 75.632 -41.2217 1270.581665 75.690 -38.6085 1279.788818 75.794 -36.1575 1289.062744 75.936 -33.9440 1298.403809 76.105 -32.0280 1307.812622 76.289 -30.4517 1317.289551 76.478 -29.2382 1326.835205 76.664 -28.3912 1336.449951 76.838 -27.8970 1346.134399 76.995 -27.7268 1355.889038 77.133 -27.8398 1365.714355 77.248 -28.1866 1375.610840 77.338 -28.7120 1385.579102 77.405 -29.3588 1395.619629 77.448 -30.0696 1405.732910 77.468 -30.7903 1415.919434 77.468 -31.4720 1426.179810 77.450 -32.0725 1436.514526 77.418 -32.5583 1446.924072 77.377 -32.9060 1457.409058 77.331 -33.1022 1467.970093 77.286 -33.1443 1478.607666 77.246 -33.0394 1489.322266 77.217 -32.8039 1500.114502 77.204 -32.4612 1510.984985 77.209 -32.0397 1521.934204 77.234 -31.5707 1532.962769 77.280 -31.0853 1544.071289 77.346 -30.6129 1555.260254 77.428 -30.1788 1566.530273 77.525 -29.8031 1577.881958 77.634 -29.5001 1589.315918 77.750 -29.2782 1600.832764 77.873 -29.1406 1612.433105 77.999 -29.0864 1624.117432 78.129 -29.1115 1635.886475 78.260 -29.2104 1647.740723 78.393 -29.3777 1659.680908 78.527 -29.6088 1671.707642 78.663 -29.9015 1683.821533 78.801 -30.2561 1696.023193 78.940 -30.6761 1708.313232 79.080 -31.1675 1720.692383 79.220 -31.7383 1733.161255 79.357 -32.3975 1745.720459 79.491 -33.1539 1758.370728 79.618 -34.0145 1771.112549 79.736 -34.9830 1783.946777 79.842 -36.0583 1796.874023 79.934 -37.2340 1809.894897 80.008 -38.4966 1823.010132 80.064 -39.8260 1836.220459 80.099 -41.1962 1849.526489 80.111 -42.5752 1862.928955 80.101 -43.9279 1876.428467 80.067 -45.2169 1890.025879 80.012 -46.4060 1903.721802 79.937 -47.4622 1917.516968 79.844 -48.3584 1931.412109 79.738 -49.0764 1945.407959 79.622 -49.6078 1959.505127 79.503 -49.9551 1973.704468 79.385 -50.1323 1988.006714 79.276 -50.1636 2002.412598 79.181 -50.0809 2016.922852 79.104 -49.9224 2031.538330 79.048 -49.7281 2046.259644 79.016 -49.5380 2061.087646 79.005 -49.3877 2076.023193 79.013 -49.3073 2091.066895 79.037 -49.3188 2106.219727 79.072 -49.4358 2121.482178 79.113 -49.6627 2136.855225 79.155 -49.9960 2152.339844 79.196 -50.4246 2167.936523 79.231 -50.9320 2183.646240 79.260 -51.4978 2199.469727 79.281 -52.0993 2215.407959 79.294 -52.7139 2231.461670 79.299 -53.3204 2247.631836 79.300 -53.9002 2263.919189 79.296 -54.4389 2280.324463 79.292 -54.9265 2296.848633 79.289 -55.3578 2313.492432 79.291 -55.7325 2330.256836 79.300 -56.0544 2347.142822 79.319 -56.3306 2364.151123 79.351 -56.5714 2381.282715 79.396 -56.7889 2398.538574 79.456 -56.9966 2415.919434 79.532 -57.2087 2433.426270 79.622 -57.4399 2451.059814 79.727 -57.7051 2468.821289 79.845 -58.0192 2486.711426 79.975 -58.3968 2504.731201 80.114 -58.8522 2522.881592 80.260 -59.3987 2541.163330 80.410 -60.0487 2559.577637 80.563 -60.8126 2578.125488 80.715 -61.6986 2596.807617 80.865 -62.7123 2615.625244 81.008 -63.8562 2634.579102 81.145 -65.1293 2653.670410 81.272 -66.5279 2672.899902 81.389 -68.0449 2692.268799 81.494 -69.6710 2711.778076 81.587 -71.3948 2731.428711 81.668 -73.2034 2751.221680 81.735 -75.0835 2771.158203 81.789 -77.0211 2791.239258 81.830 -79.0026 2811.465820 81.858 -81.0148 2831.838867 81.874 -83.0453 2852.359619 81.879 -85.0830 2873.029053 81.872 -87.1178 2893.848145 81.856 -89.1409 2914.818115 81.830 -91.1453 2935.940186 81.795 -93.1254 2957.215332 81.754 -95.0777 2978.644531 81.706 -97.0005 3000.229004 81.654 -98.8942 3021.969971 81.598 -100.7611 3043.868408 81.540 -102.6053 3065.925537 81.481 -104.4326 3088.142578 81.421 -106.2496 3110.520508 81.362 -108.0638 3133.060547 81.304 -109.8832 3155.763916 81.246 -111.7153 3178.631836 81.190 -113.5673 3201.665527 81.135 -115.4454 3224.866211 81.081 -117.3552 3248.234863 81.026 -119.3011 3271.772949 80.971 -121.2867 3295.481445 80.916 -123.3146 3319.361816 80.859 -125.3871 3343.415283 80.800 -127.5056 3367.643066 80.739 -129.6719 3392.046387 80.676 -131.8873 3416.626465 80.610 -134.1534 3441.384766 80.541 -136.4723 3466.322510 80.468 -138.8464 3491.440918 80.393 -141.2791 3516.741455 80.314 -143.7740 3542.225098 80.232 -146.3358 3567.893555 80.146 -148.9691 3593.748047 80.056 -151.6794 3619.789795 79.961 -154.4716 3646.020264 79.862 -157.3502 3672.440918 79.757 -160.3192 3699.052979 79.645 -163.3810 3725.857910 79.525 -166.5372 3752.856934 79.397 -169.7873 3780.051758 79.259 -173.1300 3807.443604 79.110 -176.5627 3835.033936 78.949 179.9175 3862.824219 78.775 176.3137 3890.815918 78.587 172.6276 3919.010254 78.385 168.8590 3947.408936 78.167 165.0048 3976.013428 77.934 161.0574 4004.825195 77.685 157.0048 4033.845703 77.421 152.8282 4063.076660 77.142 148.5033 4092.519287 76.849 143.9985 4122.175293 76.541 139.2758 4152.046387 76.221 134.2917 4182.133789 75.888 128.9975 4212.439453 75.543 123.3409 4242.964355 75.187 117.2678 4273.710449 74.820 110.7242 4304.679688 74.442 103.6584 4335.873047 74.052 96.0227 4367.292480 73.651 87.7764 4398.939453 73.238 78.8884 4430.815918 72.811 69.3381 4462.923340 72.372 59.1201 4495.263672 71.918 48.2449 4527.838379 71.450 36.7418 4560.648926 70.968 24.6603 4593.697266 70.473 12.0700 4626.984863 69.967 -0.9393 4660.513672 69.452 -14.2607 4694.285645 68.932 -27.7733 4728.302246 68.412 -41.3467 4762.565430 67.899 -54.8492 4797.077148 67.399 -68.1522 4831.838867 66.921 -81.1364 4866.852539 66.474 -93.6984 4902.119629 66.064 -105.7529 4937.642578 65.697 -117.2357 4973.422852 65.375 -128.1036 5009.462402 65.098 -138.3335 5045.763184 64.861 -147.9214 5082.326660 64.659 -156.8792 5119.155273 64.483 -165.2322 5156.250977 64.326 -173.0171 5193.615234 64.183 179.7209 5231.250488 64.046 172.9303 5269.158203 63.912 166.5552 5307.340820 63.778 160.5369 5345.799805 63.641 154.8164 5384.537598 63.501 149.3359 5423.556152 63.355 144.0408 5462.857422 63.203 138.8810 5502.443359 63.044 133.8125 5542.316406 62.878 128.7993 5582.478516 62.702 123.8137 5622.931641 62.515 118.8368 5663.677734 62.316 113.8586 5704.719238 62.103 108.8773 5746.058105 61.874 103.8995 5787.696289 61.628 98.9379 5829.636230 61.363 94.0105 5871.880371 61.079 89.1399 5914.430664 60.773 84.3508 5957.289062 60.446 79.6704 6000.458008 60.097 75.1252 6043.939941 59.725 70.7407 6087.736816 59.330 66.5405 6131.851074 58.912 62.5447 6176.285156 58.471 58.7681 6221.041016 58.008 55.2203 6266.121094 57.523 51.9047 6311.527832 57.015 48.8170 6357.263672 56.488 45.9465 6403.331055 55.940 43.2753 6449.732422 55.372 40.7791 6496.469727 54.787 38.4283 6543.545898 54.185 36.1897 6590.962891 53.568 34.0269 6638.723633 52.937 31.9026 6686.830566 52.295 29.7805 6735.286133 51.644 27.6265 6784.092773 50.986 25.4097 6833.252930 50.326 23.1049 6882.769531 49.668 20.6927 6932.645020 49.016 18.1609 6982.881836 48.378 15.5040 7033.482910 47.759 12.7231 7084.450195 47.169 9.8245 7135.787109 46.616 6.8175 7187.496094 46.113 3.7129 7239.579590 45.668 0.5205 7292.040527 45.292 -2.7520 7344.881836 44.993 -6.0991 7398.105957 44.776 -9.5173 7451.715820 44.640 -13.0020 7505.713867 44.581 -16.5448 7560.103516 44.592 -20.1301 7614.887207 44.665 -23.7316 7670.067871 44.790 -27.3101 7725.648438 44.960 -30.8135 7781.631836 45.171 -34.1786 7838.020508 45.418 -37.3353 7894.817871 45.702 -40.2130 7952.026855 46.019 -42.7485 8009.650391 46.371 -44.8954 8067.691406 46.753 -46.6316 8126.153320 47.162 -47.9672 8185.038574 47.594 -48.9471 8244.350586 48.041 -49.6510 8304.092773 48.497 -50.1870 8364.267578 48.957 -50.6825 8424.878906 49.414 -51.2708 8485.928711 49.864 -52.0776 8547.420898 50.304 -53.2090 8609.359375 50.731 -54.7422 8671.746094 51.144 -56.7222 8734.584961 51.543 -59.1613 8797.878906 51.928 -62.0436 8861.631836 52.300 -65.3320 8925.846680 52.660 -68.9747 8990.527344 53.008 -72.9132 9055.676758 53.347 -77.0891 9121.297852 53.676 -81.4491 9187.394531 53.996 -85.9481 9253.969727 54.306 -90.5515 9321.027344 54.606 -95.2347 9388.571289 54.893 -99.9821 9456.604492 55.168 -104.7843 9525.130859 55.428 -109.6357 9594.154297 55.671 -114.5309 9663.677734 55.898 -119.4614 9733.705078 56.106 -124.4146 9804.239258 56.298 -129.3710 9875.285156 56.473 -134.3054 9946.845703 56.635 -139.1876 10018.924805 56.786 -143.9846 10091.526367 56.933 -148.6642 10164.653320 57.079 -153.1985 10238.310547 57.231 -157.5680 10312.501953 57.395 -161.7654 10387.230469 57.576 -165.7976 10462.500977 57.777 -169.6881 10538.316406 57.998 -173.4763 10614.681641 58.239 -177.2161 10691.599609 58.495 179.0283 10769.075195 58.762 175.1859 10847.112305 59.033 171.1849 10925.714844 59.301 166.9576 11004.886719 59.560 162.4446 11084.632812 59.805 157.5985 11164.957031 60.031 152.3856 11245.863281 60.234 146.7859 11327.355469 60.412 140.7925 11409.438477 60.561 134.4095 11492.116211 60.681 127.6495 11575.392578 60.770 120.5304 11659.272461 60.828 113.0726 11743.760742 60.854 105.2968 11828.861328 60.850 97.2211 11914.578125 60.814 88.8608 12000.916016 60.747 80.2261 12087.879883 60.649 71.3208 12175.473633 60.521 62.1448 12263.702148 60.364 52.6912 12352.570312 60.178 42.9482 12442.082031 59.963 32.8997 12532.242188 59.720 22.5254 12623.055664 59.450 11.8022 12714.527344 59.153 0.7051 12806.662109 58.830 -10.7928 12899.464844 58.482 -22.7170 12992.939453 58.109 -35.0923 13087.091797 57.712 -47.9412 13181.925781 57.293 -61.2827 13277.447266 56.851 -75.1328 13373.661133 56.389 -89.5028 13470.572266 55.907 -104.4005 13568.185547 55.406 -119.8301 13666.505859 54.887 -135.7926 13765.539062 54.351 -152.2861 13865.290039 53.799 -169.3059 13965.763672 53.233 173.1562 14066.965820 52.652 155.1139 14168.900391 52.058 136.5885 14271.574219 51.452 117.6128 14374.992188 50.834 98.2349 14479.159180 50.205 78.5232 14584.081055 49.567 58.5695 14689.763672 48.920 38.4915 14796.211914 48.268 18.4320 14903.431641 47.614 -1.4448 15011.427734 46.964 -20.9597 15120.207031 46.326 -39.9329 15229.774414 45.711 -58.1913 15340.135742 45.135 -75.5857 15451.296875 44.617 -91.9990 15563.263672 44.178 -107.3552 15676.041016 43.838 -121.6204 15789.635742 43.609 -134.8027 15904.053711 43.495 -146.9468 16019.300781 43.485 -158.1257 16135.382812 43.563 -168.4316 16252.306641 43.708 -177.9653 16370.077148 43.898 173.1699 16488.701172 44.116 164.8779 16608.185547 44.351 157.0730 16728.535156 44.591 149.6838 16849.757812 44.833 142.6533 16971.857422 45.071 135.9399 17094.841797 45.304 129.5151 17218.718750 45.530 123.3625 17343.492188 45.747 117.4775 17469.169922 45.954 111.8647 17595.757812 46.150 106.5396 17723.263672 46.332 101.5256 17851.693359 46.498 96.8555 17981.054688 46.647 92.5684 18111.353516 46.777 88.7073 18242.595703 46.887 85.3137 18374.789062 46.977 82.4214 18507.939453 47.047 80.0493 18642.054688 47.099 78.1946 18777.142578 47.136 76.8281 18913.208984 47.159 75.8936 19050.261719 47.173 75.3118 19188.308594 47.180 74.9907 19327.355469 47.183 74.8391 19467.410156 47.184 74.7810 19608.478516 47.185 74.7642 19750.570312 47.185 74.7610 19893.691406 47.185 74.7607 **END FRD 1 for driver 2 **ZMA Data for driver 2 1.029 7.020 2.733 1.059 7.020 2.733 1.091 7.020 2.733 1.122 7.020 2.733 1.155 7.020 2.733 1.189 7.020 2.733 1.224 7.020 2.733 1.260 7.020 2.733 1.297 7.020 2.733 1.335 6.906 9.693 1.374 6.906 9.693 1.414 6.906 9.693 1.456 6.906 9.693 1.498 6.906 9.693 1.542 6.906 9.693 1.587 6.906 9.693 1.634 6.906 9.693 1.682 6.906 9.693 1.731 6.906 9.693 1.782 6.906 9.693 1.834 6.906 9.693 1.888 6.906 9.693 1.943 6.906 9.693 2.000 6.965 15.499 2.059 6.965 15.499 2.119 6.965 15.499 2.181 6.965 15.499 2.245 6.965 15.499 2.311 6.965 15.499 2.378 6.965 15.499 2.448 6.965 15.499 2.520 6.965 15.499 2.594 6.965 15.499 2.670 7.209 19.885 2.748 7.209 19.885 2.828 7.209 19.885 2.911 7.209 19.885 2.997 7.209 19.885 3.084 7.209 19.885 3.175 7.209 19.885 3.268 7.209 19.885 3.364 7.500 24.751 3.462 7.500 24.751 3.564 7.500 24.751 3.668 7.500 24.751 3.775 7.500 24.751 3.886 7.500 24.751 4.000 7.872 29.484 4.117 7.872 29.484 4.238 7.872 29.484 4.362 7.872 29.484 4.490 7.872 29.484 4.621 7.872 29.484 4.757 8.367 34.216 4.896 8.367 34.216 5.040 8.367 34.216 5.187 8.367 34.216 5.339 8.983 38.821 5.496 8.983 38.821 5.657 8.983 38.821 5.823 8.983 38.821 5.993 9.783 43.167 6.169 9.783 43.167 6.350 9.783 43.167 6.536 9.783 43.167 6.727 10.750 47.334 6.924 10.750 47.334 7.127 10.750 47.334 7.336 11.958 51.126 7.551 11.958 51.126 7.772 11.958 51.126 8.000 13.453 54.760 8.234 13.453 54.760 8.476 13.453 54.760 8.724 15.349 57.767 8.980 15.349 57.767 9.243 15.349 57.767 9.514 17.715 60.501 9.792 17.715 60.501 10.079 20.971 62.392 10.375 20.971 62.392 10.679 25.340 63.488 10.992 25.340 63.488 11.314 31.888 63.086 11.645 31.888 63.086 11.986 41.992 60.358 12.338 41.992 60.358 12.699 58.966 53.136 13.071 58.966 53.136 13.454 83.941 36.748 13.849 83.941 36.748 14.254 98.759 8.191 14.672 94.580 -22.555 15.102 94.580 -22.555 15.545 73.451 -45.782 16.000 50.613 -55.985 16.469 50.613 -55.985 16.951 38.548 -59.212 17.448 31.082 -60.375 17.959 26.326 -59.977 18.486 26.326 -59.977 19.027 22.972 -59.625 19.585 19.536 -57.947 20.159 18.726 -57.365 20.749 17.111 -56.130 21.357 15.776 -54.822 21.983 14.700 -53.492 22.627 13.743 -52.144 23.290 12.980 -50.602 23.973 12.298 -49.229 24.675 11.698 -47.607 25.398 11.191 -46.013 26.143 10.748 -44.283 26.909 10.378 -42.584 27.697 10.048 -40.852 28.509 9.809 -39.153 29.344 9.503 -36.885 30.204 9.262 -34.902 31.089 9.084 -33.647 32.000 8.858 -31.803 32.938 8.634 -29.897 33.903 8.445 -27.729 34.896 8.292 -25.487 35.919 8.152 -23.082 36.971 8.035 -20.619 38.055 7.958 -17.536 39.170 7.930 -13.796 40.317 7.959 -11.334 41.499 8.071 -8.396 42.715 8.323 -4.820 43.967 8.652 -1.486 45.255 9.135 1.887 46.581 9.928 4.170 47.946 10.884 5.267 49.351 11.986 5.705 50.797 13.377 4.445 52.285 14.728 2.049 53.817 16.043 -4.757 55.394 16.509 -12.766 57.018 16.352 -18.542 58.688 15.516 -26.749 60.408 14.313 -32.063 62.178 12.896 -35.656 64.000 11.547 -36.758 65.875 10.301 -36.126 67.806 9.392 -34.345 69.792 8.756 -31.876 71.838 8.330 -29.299 73.943 8.039 -26.837 76.109 7.835 -24.465 78.339 7.675 -21.962 80.635 7.592 -20.016 82.998 7.525 -18.377 85.430 7.446 -16.856 87.933 7.373 -15.441 90.510 7.300 -13.522 93.162 7.310 -11.723 95.892 7.325 -10.244 98.701 7.300 -9.174 101.594 7.247 -7.921 104.571 7.207 -6.337 107.635 7.227 -4.610 110.789 7.296 -2.788 114.035 7.397 -1.206 117.377 7.583 0.470 120.816 7.978 0.950 124.356 8.232 -1.170 128.000 8.089 -3.446 131.751 7.610 -3.702 135.611 7.297 -0.663 139.585 7.279 1.965 143.675 7.355 4.372 147.885 7.507 6.478 152.219 7.767 8.135 156.679 8.044 9.044 161.270 8.279 9.824 165.995 8.646 10.457 170.860 9.054 9.461 175.866 9.195 7.315 181.019 9.112 6.519 186.324 9.150 7.015 191.783 9.538 6.714 197.403 9.826 3.825 203.187 9.660 0.117 209.141 9.026 -2.274 215.269 8.391 -1.552 221.577 8.035 0.644 228.070 7.884 3.093 234.753 7.861 5.142 241.632 7.900 6.937 248.712 8.012 8.483 256.000 8.177 9.371 263.501 8.330 9.290 271.223 8.333 8.797 279.170 8.217 8.702 287.350 8.060 9.688 295.770 8.008 11.150 304.437 8.048 12.482 313.358 8.127 13.433 322.540 8.158 14.093 331.991 8.171 14.909 341.719 8.191 15.915 351.732 8.250 16.888 362.039 8.293 17.745 372.647 8.338 18.721 383.567 8.415 19.836 394.806 8.523 20.835 406.375 8.642 21.575 418.282 8.744 22.212 430.539 8.829 22.727 443.155 8.887 23.595 456.140 8.998 24.476 469.506 9.139 25.317 483.264 9.286 25.764 497.424 9.399 26.264 512.000 9.513 26.715 527.003 9.623 27.134 542.445 9.700 27.564 558.340 9.762 28.077 574.701 9.839 28.783 591.541 9.931 29.530 608.874 10.044 30.355 626.715 10.171 31.154 645.080 10.323 31.950 663.982 10.487 32.709 683.438 10.666 33.396 703.464 10.855 34.042 724.077 11.069 34.627 745.294 11.307 35.059 767.133 11.540 35.187 789.612 11.713 35.103 812.749 11.806 35.177 836.565 11.892 35.596 861.078 12.018 36.196 886.309 12.167 36.784 912.280 12.339 37.444 939.012 12.559 38.085 966.527 12.822 38.507 994.849 13.059 38.641 1024.000 13.234 38.685 1054.005 13.370 38.901 1084.890 13.491 39.319 1116.680 13.625 39.865 1149.401 13.787 40.511 1183.081 13.987 41.225 1217.748 14.226 41.912 1253.431 14.486 42.519 1290.159 14.762 43.086 1327.964 15.050 43.655 1366.876 15.362 44.153 1406.929 15.694 44.562 1448.155 16.016 44.865 1490.589 16.319 45.217 1534.266 16.658 45.631 1579.224 17.058 45.917 1625.499 17.416 45.992 1673.129 17.710 46.231 1722.156 18.061 46.808 1772.619 18.621 47.378 1824.561 19.360 47.135 1878.024 19.831 45.758 1933.055 19.799 44.706 1989.697 19.658 45.203 2048.000 19.964 46.375 2108.011 20.565 46.996 2169.780 21.177 46.726 2233.360 21.546 46.079 2298.802 21.689 45.753 2366.162 21.869 46.068 2435.496 22.237 46.565 2506.862 22.832 46.695 2580.318 23.271 46.008 2655.927 23.332 45.489 2733.752 23.321 45.963 2813.857 23.670 46.742 2896.309 24.125 47.098 2981.178 24.568 47.325 3068.533 25.030 47.426 3158.448 25.414 47.303 3250.997 25.639 47.379 3346.259 25.917 47.842 3444.312 26.324 48.402 3545.238 26.828 48.944 3649.121 27.492 49.432 3756.049 28.279 49.353 3866.109 28.777 48.800 3979.395 29.013 48.643 4096.000 29.345 48.999 4216.022 29.864 49.223 4339.561 30.298 49.267 4466.720 30.645 49.484 4597.605 31.057 49.954 4732.325 31.618 50.476 4870.992 32.275 50.865 5013.723 32.954 51.127 5160.637 33.629 51.334 5311.855 34.313 51.500 5467.504 35.016 51.631 5627.714 35.719 51.726 5792.619 36.424 51.802 5962.355 37.118 51.878 6137.066 37.827 51.955 6316.896 38.558 52.009 6501.995 39.292 52.043 6692.518 40.016 52.074 6888.623 40.739 52.127 7090.476 41.487 52.197 7298.242 42.263 52.272 7512.097 43.064 52.336 7732.218 43.882 52.384 7958.790 44.717 52.416 8192.000 45.563 52.434 8432.044 46.416 52.441 8679.122 47.277 52.440 8933.439 48.144 52.435 9195.209 49.012 52.445 9464.649 49.904 52.462 9741.985 50.826 52.471 10027.447 51.764 52.457 10321.273 52.709 52.442 10623.710 53.671 52.429 10935.008 54.670 52.404 11255.428 55.681 52.329 11585.238 56.651 52.230 11924.711 57.582 52.179 12274.132 58.550 52.184 12633.791 59.574 52.208 13003.989 60.637 52.210 13385.035 61.733 52.192 13777.247 62.839 52.146 14180.951 63.912 52.060 14596.485 64.937 52.022 15024.194 65.995 52.050 15464.437 67.153 52.083 15917.579 68.348 52.077 16384.000 69.551 52.050 16864.088 70.757 52.026 17358.243 71.984 52.011 17866.879 73.242 51.991 18390.418 74.518 51.952 18929.299 75.789 51.886 19483.969 76.986 51.821 20054.893 77.959 51.838 20642.546 78.273 52.111 **END ZMA Data for driver 2 1 //Setup 0 //Lines
