0
True
hor
ver
1
20
20000
True
True
False
True
True
False
False
False
10
False
1000
False
-1000
False
1500
False
-1000
25
2
2
2
2500
0
0
0
20.0
20000.0
85.0
0.0
1
False
False
False
20.0
20000.0
85.0
0.0
1
False
False
False
Driver #1
80
8
False
1
0
False
False
False
None
1
0
0
Driver #2
80
8
False
1
0
False
False
False
None
1
0
0
0
Analog
192000
Generator
3
9
G1
Eg
2.83
V
False
0.01
200
False
Rg
0.001
Ω
False
0.001
1000
False
3
6
3
12
Ground
15
13
False
False
15
12
Driver
130
86
Driver #1
False
False
False
False
False
D1
20.0
20000.0
85.0
0.0
1
False
False
False
20.0
20000.0
0.0
0.0
1
False
False
False
X
0
mm
False
-2000
2000
False
Y
0
mm
False
-5000
5000
False
Z
0
mm
False
-2000
2000
False
R
0
deg
False
-180
180
False
T
0
deg
False
-180
180
False
129
83
129
89
Ground
129
90
False
False
129
89
Operational Amplifier
22
8
False
False
U1
AOL
120
dB
False
20
200
False
GBP
8
MHz
False
0.1
100
False
19
6
19
10
25
8
23
9
Resistor
22
16
False
False
False
R1
R
15000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
19
16
25
16
Resistor
16
16
False
False
False
R2
R
15000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
13
16
19
16
Wire
19
16
False
19
16
19
16
Resistor
15
9
False
False
True
R3
R
15000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
15
12
15
6
Wire
17
6
False
19
6
15
6
Wire
19
13
False
19
10
19
16
Wire
8
14
False
3
12
3
16
13
16
Wire
25
12
False
25
8
25
16
Resistor
12
6
False
False
False
R4
R
15000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
9
6
15
6
Wire
6
6
False
9
6
3
6
Capacitor
31
59
False
False
True
C1
C
0.01
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
31
62
31
56
Resistor
28
56
False
False
False
R5
R
20500
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
25
56
31
56
Ground
31
63
False
False
31
62
48
58
False
False
U2
AOL
120
dB
False
20
200
False
GBP
8
MHz
False
0.1
100
False
45
56
45
60
51
58
49
59
Wire
48
60
False
51
58
51
62
45
62
45
60
Capacitor
46
53
False
False
False
C2
C
0.01
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
43
53
49
53
Wire
50
55
False
49
53
51
53
51
58
Capacitor
43
59
False
False
True
C3
C
0.001
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
43
62
43
56
Ground
43
63
False
False
43
62
Resistor
40
56
False
False
False
R6
R
26100
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
37
56
43
56
Resistor
34
56
False
False
False
R7
R
147000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
31
56
37
56
Wire
40
54
False
43
53
37
53
37
56
Wire
44
56
False
43
56
45
56
Wire
25
36
False
25
16
25
56
Ground
31
15
False
False
31
14
48
10
False
False
U3
AOL
120
dB
False
20
200
False
GBP
8
MHz
False
0.1
100
False
45
8
45
12
51
10
49
11
Wire
48
12
False
51
10
51
14
45
14
45
12
Wire
50
7
False
49
5
51
5
51
10
Ground
43
15
False
False
43
14
Wire
40
6
False
43
5
37
5
37
8
Wire
44
8
False
43
8
45
8
Capacitor
28
8
False
False
False
C7
C
0.0047
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
25
8
31
8
Capacitor
34
8
False
False
False
C8
C
0.0047
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
31
8
37
8
Capacitor
40
8
False
False
False
C9
C
0.0047
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
37
8
43
8
Resistor
31
11
False
False
True
R11
R
30100
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
31
14
31
8
Resistor
46
5
False
False
False
R12
R
11800
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
43
5
49
5
Resistor
43
11
False
False
True
R13
R
210000
Ω
False
0.01
10000000
False
Pow
5
W
False
0.1
1000
False
43
14
43
8
Buffer
123
84
False
False
False
A1
A
0
dB
False
-100
100
False
dt
0
us
False
-50000
50000
False
120
83
120
85
126
83
126
85
Wire
127
83
False
126
83
129
83
Driver
106
23
Driver #2
False
False
False
False
False
D2
20.0
20000.0
85.0
0.0
1
False
False
False
20.0
20000.0
0.0
0.0
1
False
False
False
X
0
mm
False
-2000
2000
False
Y
0
mm
False
-5000
5000
False
Z
0
mm
False
-2000
2000
False
R
0
deg
False
-180
180
False
T
0
deg
False
-180
180
False
105
20
105
26
Ground
105
27
False
False
105
26
Buffer
99
21
False
False
False
A2
A
0
dB
False
-100
100
False
dt
0
us
False
-50000
50000
False
96
20
96
22
102
20
102
22
Wire
103
20
False
102
20
105
20
Resistor
55
13
False
False
True
R14
R
0.01
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
55
16
55
10
Resistor
55
19
False
False
True
R15
R
10000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
55
22
55
16
Resistor
55
25
False
False
True
R16
R
1100
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
55
28
55
22
Wire
53
10
False
55
10
51
10
Resistor
59
19
False
False
True
R17
R
1600
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
59
22
59
16
Ground
55
29
False
False
55
28
Wire
57
22
False
59
22
55
22
Capacitor
68
16
False
False
False
C11
C
0.001
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
65
16
71
16
Resistor
65
19
False
False
True
R18
R
1000000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
65
22
65
16
Ground
65
23
False
False
65
22
Resistor
65
12
False
False
False
R19
R
1000000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
62
12
68
12
Capacitor
62
16
False
False
False
C12
C
0.001
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
59
16
65
16
Wire
57
16
False
59
16
55
16
Wire
60
14
False
59
16
59
12
62
12
Wire
69
14
False
68
12
71
12
71
16
Resistor
65
9
False
False
False
R20
R
0.01
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
62
9
68
9
Wire
62
10
False
62
9
62
12
Wire
68
10
False
68
9
68
12
74
18
False
False
U4
AOL
120
dB
False
20
200
False
GBP
8
MHz
False
0.1
100
False
71
16
71
20
77
18
75
19
Resistor
74
26
False
False
False
R21
R
1000000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
71
26
77
26
Resistor
74
23
False
False
False
R22
R
0.01
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
71
23
77
23
Wire
71
24
False
71
23
71
26
Wire
77
24
False
77
23
77
26
Wire
71
21
False
71
20
71
23
Wire
77
20
False
77
18
77
23
Resistor
71
29
False
False
True
R23
R
1000000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
71
32
71
26
Resistor
77
29
False
False
True
R24
R
1000000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
77
32
77
26
Resistor
74
32
False
False
False
R25
R
1000000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
71
32
77
32
Capacitor
71
35
False
False
True
C13
C
0.001
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
71
38
71
32
Capacitor
77
35
False
False
True
C14
C
0.0047
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
77
38
77
32
Wire
74
38
False
71
38
74
38
77
38
Resistor
74
41
False
False
True
R26
R
12000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
74
44
74
38
Ground
74
45
False
False
74
44
Resistor
80
18
False
False
False
R27
R
2200
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
77
18
83
18
90
20
False
False
U5
AOL
120
dB
False
20
200
False
GBP
8
MHz
False
0.1
100
False
87
18
87
22
93
20
91
21
Resistor
90
25
False
False
False
R28
R
2200
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
87
25
93
25
Wire
87
23
False
87
22
87
25
Wire
93
22
False
93
20
93
25
Resistor
83
21
False
False
True
R29
R
2500
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
83
24
83
18
Resistor
83
27
False
False
True
R30
R
2500
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
83
30
83
24
Wire
85
27
False
83
30
87
30
87
25
Wire
85
18
False
87
18
83
18
Capacitor
80
27
False
False
True
C15
C
0.0022
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
80
30
80
24
Wire
81
24
False
80
24
83
24
Capacitor
80
35
False
False
True
C16
C
0.00022
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
80
38
80
32
Resistor
80
41
False
False
True
R31
R
240000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
80
44
80
38
Ground
80
45
False
False
80
44
Wire
80
38
False
80
38
80
38
90
40
False
False
U6
AOL
120
dB
False
20
200
False
GBP
8
MHz
False
0.1
100
False
87
38
87
42
93
40
91
41
Wire
90
42
False
87
42
87
45
93
45
93
40
Wire
83
38
False
87
38
80
38
Wire
80
31
False
80
32
80
30
Resistor
90
32
False
False
False
R32
R
2200
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
87
32
93
32
Wire
93
36
False
93
40
93
32
Wire
83
32
False
87
32
80
32
Wire
94
20
False
93
20
96
20
68
60
False
False
U7
AOL
120
dB
False
20
200
False
GBP
8
MHz
False
0.1
100
False
65
58
65
62
71
60
69
61
Wire
68
62
False
71
60
71
64
65
64
65
62
Wire
70
57
False
69
55
71
55
71
60
Ground
63
65
False
False
63
64
Wire
60
56
False
63
55
57
55
57
58
Wire
64
58
False
63
58
65
58
Capacitor
54
58
False
False
False
C17
C
0.1
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
51
58
57
58
Capacitor
60
58
False
False
False
C18
C
0.1
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
57
58
63
58
Resistor
66
55
False
False
False
R33
R
36000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
63
55
69
55
Resistor
63
61
False
False
True
R34
R
75000
Ω
False
0.01
10000000
False
Pow
5
W
False
0.1
1000
False
63
64
63
58
Resistor
80
60
False
False
False
R36
R
18000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
77
60
83
60
86
58
False
False
U8
AOL
120
dB
False
20
200
False
GBP
8
MHz
False
0.1
100
False
83
56
83
60
89
58
87
59
Resistor
86
63
False
False
False
R37
R
20000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
83
63
89
63
Wire
83
61
False
83
60
83
63
Wire
89
60
False
89
63
89
58
Ground
83
57
False
False
83
56
Resistor
92
63
False
False
False
R38
R
50000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
89
63
95
63
Resistor
98
63
False
False
False
R39
R
0.01
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
95
63
101
63
Capacitor
92
66
False
False
False
C19
C
100
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
89
66
95
66
Wire
95
64
False
95
66
95
63
Wire
89
64
False
89
66
89
63
Wire
89
63
False
89
63
89
63
Resistor
110
63
False
False
False
R40
R
50000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
107
63
113
63
Resistor
116
63
False
False
False
R41
R
0.01
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
113
63
119
63
Wire
107
63
False
107
63
107
63
Resistor
104
63
False
False
False
R42
R
620
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
101
63
107
63
Wire
110
64
False
107
63
107
66
113
66
113
63
Capacitor
92
58
False
False
False
C20
C
0.012
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
89
58
95
58
Wire
101
60
False
95
58
107
58
107
63
Capacitor
92
73
False
False
False
C21
C
22
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
89
73
95
73
Resistor
98
73
False
False
False
R43
R
15000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
95
73
101
73
110
71
False
False
U9
AOL
120
dB
False
20
200
False
GBP
8
MHz
False
0.1
100
False
107
69
107
73
113
71
111
72
Wire
107
67
False
107
69
107
66
Wire
89
69
False
89
66
89
73
Wire
104
73
False
101
73
107
73
Resistor
110
77
False
False
False
R44
R
56000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
107
77
113
77
Wire
107
75
False
107
77
107
73
Wire
113
74
False
113
77
113
71
Capacitor
122
63
False
False
False
C22
C
0.012
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
119
63
125
63
Resistor
128
63
False
False
False
R45
R
620
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
125
63
131
63
128
73
False
False
U10
AOL
120
dB
False
20
200
False
GBP
8
MHz
False
0.1
100
False
125
71
125
75
131
73
129
74
Wire
128
75
False
125
75
125
77
131
77
131
73
Resistor
120
71
False
False
False
R46
R
27000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
117
71
123
71
Resistor
123
74
False
False
True
R47
R
10000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
123
77
123
71
Ground
123
78
False
False
123
77
Wire
124
71
False
125
71
123
71
Wire
131
68
False
131
73
131
63
Wire
115
71
False
117
71
113
71
Wire
116
80
False
120
83
113
83
113
77
Resistor
74
60
False
False
False
R48
R
2000
Ω
False
0.01
10000000
False
Pow
0.25
W
False
0.1
1000
False
71
60
77
60
Wire
77
60
False
77
60
77
60
