0 Analog 192000 1 200 4000 10 True 50.0 85.0 15000.0 85.0 200.0 83.0 12000.0 75.0 Driver #1 80 8 False 1 0 False None 1 0 0 Driver #2 80 8 False 1 0 False None 1 0 0 0 Generator 9 21 G1 9 18 9 24 Ground 9 25 False False 9 24 Driver 92 40 Driver #1 False False False False D1 85 0 1 None 2 300 0.62 False None 2 3000 0.62 False False 1 20 20000 X 0 mm False -2000 2000 False Y 0 mm False -2000 2000 False Z 0 mm False -2000 2000 False R 0 deg False -180 180 False T 0 deg False -180 180 False 91 37 91 43 Ground 91 44 False False 91 43 Resistor 33 33 False False False R1 R 48000 Ω False 0.01 10000000 False Pow 5 W False 0.1 1000 False 30 33 36 33 Resistor 39 33 False False False R2 R 48000 Ω False 0.01 10000000 False Pow 5 W False 0.1 1000 False 36 33 42 33 Capacitor 44 38 False False True C1 C 0.00235 uF False 0.0001 100000 False ESR 0.01 Ω False 0.001 10 False 44 41 44 35 Operational Amplifier 51 35 False False U1 AOL 120 dB False 20 200 False GBP 8 MHz False 0.1 100 False 48 33 48 37 54 35 52 36 Capacitor 53 28 False False False C2 C 0.0047 uF False 0.0001 100000 False ESR 0.01 Ω False 0.001 10 False 50 28 56 28 Wire 55 31 False 56 28 56 28 56 35 54 35 Wire 45 33 False 48 33 44 33 42 33 Wire 44 34 False 44 35 44 33 44 33 Wire 51 37 False 48 37 47 37 47 39 56 39 56 35 Ground 44 42 False False 44 41 Resistor 63 35 False False False R3 R 48000 Ω False 0.01 10000000 False Pow 5 W False 0.1 1000 False 60 35 66 35 Resistor 69 35 False False False R4 R 48000 Ω False 0.01 10000000 False Pow 5 W False 0.1 1000 False 66 35 72 35 Capacitor 74 40 False False True C3 C 0.00235 uF False 0.0001 100000 False ESR 0.01 Ω False 0.001 10 False 74 43 74 37 Operational Amplifier 81 37 False False U2 AOL 120 dB False 20 200 False GBP 8 MHz False 0.1 100 False 78 35 78 39 84 37 82 38 Capacitor 83 30 False False False C4 C 0.0047 uF False 0.0001 100000 False ESR 0.01 Ω False 0.001 10 False 80 30 86 30 Wire 85 33 False 86 30 86 30 86 37 84 37 Wire 75 35 False 78 35 74 35 72 35 Wire 74 36 False 74 37 74 35 74 35 Wire 81 39 False 78 39 77 39 77 41 86 41 86 37 Ground 74 44 False False 74 43 Wire 43 30 False 50 28 36 28 36 33 Wire 45 31 False 30 37 30 33 30 25 60 25 60 31 Wire 73 30 False 80 30 66 30 66 31 Wire 58 35 False 56 35 60 35 Wire 66 33 False 66 31 66 35 Ground 91 23 False False 91 22 Operational Amplifier 51 14 False False U3 AOL 120 dB False 20 200 False GBP 8 MHz False 0.1 100 False 48 12 48 16 54 14 52 15 Wire 55 10 False 56 7 56 7 56 14 54 14 Wire 45 12 False 48 12 44 12 42 12 Wire 44 13 False 44 14 44 12 44 12 Wire 51 16 False 48 16 47 16 47 18 56 18 56 14 Ground 44 21 False False 44 20 Operational Amplifier 81 16 False False U4 AOL 120 dB False 20 200 False GBP 8 MHz False 0.1 100 False 78 14 78 18 84 16 82 17 Wire 85 12 False 86 9 86 9 86 16 84 16 Wire 75 14 False 78 14 74 14 72 14 Wire 74 15 False 74 16 74 14 74 14 Wire 81 18 False 78 18 77 18 77 20 86 20 86 16 Ground 74 23 False False 74 22 Wire 43 9 False 50 7 36 7 36 12 Wire 73 9 False 80 9 66 9 66 10 Wire 58 14 False 56 14 60 14 Wire 66 12 False 66 10 66 14 Capacitor 33 12 False False False C5 C 0.0047 uF False 0.0001 100000 False ESR 0.01 Ω False 0.001 10 False 30 12 36 12 Capacitor 39 12 False False False C6 C 0.0047 uF False 0.0001 100000 False ESR 0.01 Ω False 0.001 10 False 36 12 42 12 Capacitor 63 14 False False False C7 C 0.0047 uF False 0.0001 100000 False ESR 0.01 Ω False 0.001 10 False 60 14 66 14 Capacitor 69 14 False False False C8 C 0.0047 uF False 0.0001 100000 False ESR 0.01 Ω False 0.001 10 False 66 14 72 14 Resistor 44 17 False False True R5 R 48000 Ω False 0.01 10000000 False Pow 5 W False 0.1 1000 False 44 20 44 14 Resistor 53 7 False False False R6 R 24000 Ω False 0.01 10000000 False Pow 5 W False 0.1 1000 False 50 7 56 7 Resistor 74 19 False False True R7 R 48000 Ω False 0.01 10000000 False Pow 5 W False 0.1 1000 False 74 22 74 16 Resistor 83 9 False False False R8 R 24000 Ω False 0.01 10000000 False Pow 5 W False 0.1 1000 False 80 9 86 9 Wire 88 16 False 86 16 91 16 Wire 88 37 False 86 37 91 37 Wire 45 8 False 30 12 30 4 60 4 Wire 60 7 False 60 4 60 10 Driver 92 19 Driver #2 False False False False D2 85 0 1 None 2 300 0.62 False None 2 3000 0.62 False False 1 20 20000 X 0 mm False -2000 2000 False Y 0 mm False -2000 2000 False Z 0 mm False -2000 2000 False R 0 deg False -180 180 False T 0 deg False -180 180 False 91 16 91 22 Operational Amplifier 25 12 False False U5 AOL 120 dB False 20 200 False GBP 8 MHz False 0.1 100 False 22 10 22 14 28 12 26 13 Operational Amplifier 25 33 False False U6 AOL 120 dB False 20 200 False GBP 8 MHz False 0.1 100 False 22 31 22 35 28 33 26 34 Wire 29 12 False 28 12 30 12 Wire 29 33 False 28 33 30 33 Wire 25 36 False 22 35 21 35 21 37 30 37 Wire 25 15 False 22 14 21 14 21 16 30 16 Wire 30 14 False 30 12 30 16 Resistor 18 34 False False True R9 R 49000 Ω False 0.01 10000000 False Pow 5 W False 0.1 1000 False 18 37 18 31 Resistor 18 28 False False True R10 R 1000 Ω False 0.01 10000000 False Pow 5 W False 0.1 1000 False 18 31 18 25 Ground 18 38 False False 18 37 Wire 20 31 False 18 31 22 31 Resistor 18 13 False False True R11 R 49000 Ω False 0.01 10000000 False Pow 5 W False 0.1 1000 False 18 16 18 10 Resistor 18 7 False False True R12 R 1000 Ω False 0.01 10000000 False Pow 5 W False 0.1 1000 False 18 10 18 4 Ground 18 17 False False 18 16 Wire 20 10 False 18 10 22 10 Wire 16 14 False 18 4 14 4 14 16 14 25 18 25 Wire 11 17 False 9 18 9 16 14 16 Comment 59 21 6-24 active crossover False False True False
